802.11ac, 80+80 and/or 160MHz channels - hostapd interop fix
sfx2000
Part of the Furniture
Interesting... with devices that support the newer 160MHz modes (80+80 or 160), some older clients may have problems with those information elements to determine how to configure their mode...
@thiggins - this might be a good test case for the Router/AP's...
@RMerlin, @Voxel - might want to take a look at the hostapd for devices that support 160MHz...
screenshot posted as we don't want cloudflare to trigger...
Overrated if you living packed among others, but useful if you live far from a neighbor.
Sence wide 80MHz+80MHz and 160MHz channels improve throughput only when full channel bandwidth is free from interfering transmissions.
I'm still trying to figure out all this talk about 80+80 or 160. What is it exactly?
With 160MHz channels - some regions do not have contiguous spectrum to support the full span of a 160MHz channel, so 11ac can support both the 160Mhz span, plus they can support two 80MHz channels running concurrently...
