A computer is not showing in the Clients list
Patrick9876
This morning the wireless adapter in my wife's laptop died. I plugged in a WiFi dongle, set the appropriate wireless profiles, and she was back in business. However, the connection was slow so I checked in my router - RT-AC86U running Merlin 386.4 - and the laptop did not appear in the Clients list. I see messages in the log showing the dnsqmasq dhcp giving the laptop an IP address, and this router is the laptop's only access to my LAN and the internet so I know router is correctly (or at least effectively) communicating with the laptop. Is there something I need to do to make the computer show as a client?
It will eventually show up over time. Client List is not perfect.
If you ping the broadcast IP i.e. 192.168.1.255 or whatever subnet you're using it should populate the ARP table i.e. client list.
That didn't work. I got 100% packet loss and nothing changed in the client list. Pinging the missing computer's IP address resulted in a good ping but still didn't change the client list.
There are multiple reports of this problem. No solution that I'm aware of and nothing that Merlin can do because it's closed-source.
Thanks. I suspect this is not the highest priority bug that ASUS is working on. It will probably be with us for a while.
