Client List on RT-AX88U Pro incorrectly showing a VLAN Device on the Primary Network; incorrectly showing Static device as DHCP
Client List indeed had issues forever in flat network design. With the addition of VLANs running separate DHCP servers the challenge is even bigger. This GNP you are seeing now is going away after 3006 37xxx update, in case AX-class devices get there. Whatever you are testing may be just temporary transitional situation. You have a lot more testing, reboots and resets ahead of you...
Not really related to this thread, but the release notes included with 102_4 alpha state that Merlin is using 3006.102_36521 for the wifi 6 devices. I guess it will be interesting to see what happens when Merlin moves to a 37xxx GPL. That aside, I don't expect the client list to be fixed until ASUS decides to completely rebuild it.
Don`t compare version numbers, they are parallel firmware branches. 36xxx is currently the newest available for Wifi 6 devices, while 37xxx is for Wifi 7 devices. And Expert Wifi devices are currently on 44xxx.
