AC-88U 384.10_2 CPU usage discrepancies
cyph
I have a question regarding the CPU usage. In the Merlin GUI, it shows the CPU as pegging at 98-99% constantly. However, using top command from SSH, CPU is pegged at 50-55%.
I also noticed that when I reboot the router, the GUI will show CPU usage between 50-80%. However, after a day it's always showing 95%+ constantly. However, top tells a different story. Bug or working as intended?
Look at the top (...) of the top output. Some CPU usage comes from sirq, I/O, etc...
Using H to switch between CPU's they are all in the 50% range.
Also, here is the CPU usage when it first start up:
After about a day, the CPU is constantly pegged at 98%.
Also this is the temperature with the CPU not pegged at max:
Once CPU is pegged at 98%, the temperature jumps to 184 F constant.
This is the top CPU usage when router first start up. It appears to be about 50% of what the ASUS GUI reports:
No, the webui is accurate. 36% of one core + 70% of a second core roughly equals 50% of TWO cores.
36/100 + 70/100 = 106/200
Are you using WTFast? I tried it out for a few min when I first got my router, and noticed very heavy CPU usage while it was enabled. At least one core was pegged at 100% utilization while the others bounced all over the place at a min of ~50%. As soon as I disabled it everything went back to normal. I have the AX88U, and it was all four cores.
Three hours later, the CPU is ow pegged at 95-98% constant. After reboot, the CPU process goes up and down normally. I haven't enabled anything extra since reboot. Something is causing the CPU to go into overdrive after a few hours. Temperature is now at 192 F.
Edit: Also notice how the graph doesn't have any information before. It think the temperature just spiked when it didn't. After reboot the graph was normal.
No I didn't enable that. I did enable AIProtection. I may disable that and see if it helps. What I don't understand is this only happens after a few hours. It's normal for the first few hours after reboot.
Ah OK. I thought it was worth a shot. I'm sorry that it didn't help you.
Good luck finding what is causing it. That would drive me crazy until I got it fixed.
Well, I think I resolved the issue but I have no idea which of the changes fixed it.
I uninstalled spdMerlin and ntpMerlin NTP daemon. I can't say for sure that either caused it but it's 4 hours later and the CPU spike no longer occurs.
had this last week and had been happening anytime i put diversion on.
you have to start again.
format usb in ext 4 format.
then re format the jffs on next boot.
there is a thread lurking about about how to install amtm....
It's already in ext 4. You're saying I have to reformat jffs to get rid of this issue?
I've installed diversion via amtm.
There have been issues with Diversion trying to process the ash_history file if it's corrupted and consuming CPU. Since in your original screenshot there is a diversion script at the top of the list, I wonder if this is the same issue. If that top process has ash_history on the far right next time, try removing the offending file (rm /tmp/home/root/.ash_history).
Update. Ever since I turned of AI Protection and diversion, reboot, turned diversion back on, tested it, and then turned on AI Protection, everything is back to normal again.
Yes, likewise - thanks
