Wifi keeps dropping or is relatively slow.
I tried re-installing the firmware listed above and the issue is still occurring.
Also my logs keep showing:
Dec 9 00:04:17 syslog: wlceventd_proc_event(527): eth2: Auth D2:9E:35:08:75:6F, status: Successful (0), rssi:0
Dec 9 00:04:17 syslog: wlceventd_proc_event(556): eth2: Assoc D2:9E:35:08:75:6F, status: Successful (0), rssi:0
Dec 9 00:23:55 syslog: wlceventd_proc_event(508): eth2: Disassoc BE:AB:03
4
1:21, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Dec 9 00:28:14 syslog: wlceventd_proc_event(491): eth2: Deauth_ind CE:F2
0:80:6E:6F, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Dec 9 00:28:15 syslog: wlceventd_proc_event(527): eth2: Auth CE:F2
0:80:6E:6F, status: Successful (0), rssi:0
Dec 9 00:28:15 syslog: wlceventd_proc_event(556): eth2: Assoc CE:F2
Dec 9 00:40:10 syslog: wlceventd_proc_event(491): eth2: Deauth_ind CE:F2
0:80:6E:6F, status: 0, reason: Disassociated due to inactivity (4), rssi:0
Dec 9 00:40:10 syslog: wlceventd_proc_event(508): eth2: Disassoc CE:F2
0:80:6E:6F, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Dec 9 00:40:35 syslog: wlceventd_proc_event(527): eth2: Auth CE:F2
Dec 9 00:40:35 syslog: wlceventd_proc_event(556): eth2: Assoc CE:F2
Any ideas what could be causing this?
CPU usage is fairly low.
Otherwise I have diversion installed, but after the re-flash the same logs as above kept appearing so I assumed diversion wasnt causing it.
