AC56u NAT loopback problem
grahnen
Hi
I posted this in another thread but it seems to be dead so i will try again as I have seen that others have simillar issue.
Im using port 8800 for REST communication
So my phone app is trying to communicate with my dyndns name both home and when im out. But for now I cant get it to work on wifi at home. I need to manually change from my dyndns host to my local ip every time Im home. Or disable wifi on my phone to make it work.
This means that both Dyndns and my server is working as I can get connection outside my home or by local ip.
I had no problem with this on my dir-855 but with asus ac56u it doensnt and its the only thing im missing.
Im currentlty using the latest stable rmerlin build from 4 oct.
I have also managed to get work for a couple of sec when the device was booting but I could be wrong.
Also when I try to communicate with the app on my phone on port 7999 I get a connection refused directly but on port 8000 it feels like it makes conntact but when the app is "checking server version" it freezes and waits for timeout.
Turning off hardware accelerator under lan - switch control made the trick so now it works for me.
Even loopback on port 80 works now.
