AC68U crashing when mounting external usb disk
bROTHER
v376.47 here. Never seen this before:
I have a My Passport ext4 formatted drive attached with an amule client running.
Yesterday I saw two files stopped on amule and when trying to resume them I got error on both. Very strange. When tried to restart amule client it refused to load again complaining about config folder permissions... stranger indeed.
So, I unmounted the disk and now everytime I reconnect it again the whole router crashes and it does not come back to life until I unplug the disk.
I tested on both my AC68U units ang gor the same result. I surface tested the disk and founf nothing, but cannot test its FS.
Any ideas before formatting again the disk?
This is an excerpt from syslog:
Jan  1 01:00:13 syslogd started: BusyBox v1.20.2
Jan  1 01:00:13 kernel: klogd started: BusyBox v1.20.2 (2014-09-20 14:50:46 EDT)
Jan  1 01:00:13 kernel:  modul        <4>module:  usbcore. bf4a7000. 107711
Jan  1 01:00:13 kernel: >>> module:  jffs2. bf48600        o_gre. bf46a000. 1047
Jan  1 01:00:13 kernel: >>> module:                                00. 3499
Jan  1 01:00:13 kernel: >>> module:  nf_nat_ftp. bf45e000. 1314
Jan  1 01:00:13 kernel: >>> module:  nf_conntrack_ftp. bf457000. 5131
Jan  1 01:00:13 kernel: >>>                                 4>module:  igs. bf022000. 12935
Jan  1 01:00:13 kernel: >>>        usbnet mii usblp ohci_hcd ehci_h        jbd mbcache usb_storage sg sd_mod scsi_wait_scan scsi_mod usbcor                                 nf_conntrack_pptp nf_nat_proto_gre nf_conntrack_proto_gre nf_na
Jan  1 01:00:13 kernel: >>> r7 :        g (pid: 540, stack limit = 0xce7        0 c0404ee8 c03c2948 c0409c9c
Jan  1 01:00:13 kernel: >>> 1d60: cf55b500 bf5a6f38 02462b04        00 ce7b1e00 00000000 ce7b1e00 ce5ee400 bf5ab3e8
Jan  1 01:00:13 kernel: >>> 1dc0: 0000100
Jan  1 01:00:13 kernel: >>> 1de0: c0409c40 c03c691c 0000        0000000 00000000 00000000 000000        1e00
Jan  1 01:00:13 kernel: >>> 1e60: ccc2d000 ccc2d000        0000004 cf40a600 00000003 cf40a6        0 31616473 00000000 ce6685c0 ce7                                 ce7cd6f8 ce7cd700 ccc2d000 ce7cd6e0 bf5c7d58 ce6685c0 00000000 ccc2d000
Jan  1 01:00:13 kernel: >>> 1ee0: ce7f1f48 bf5a5        0: bf5c7d58 ce6685a0 ccc2d000 ce        f40: 00000000 bea45fda cf8ce820
Jan  1 01:00:13 kernel: >>> 1fe0: 4038372c bea3d648 00065668 4038373c 20                                c
Jan  1 01:00:13 kernel: >>> [<c016d704>] (PC is at __percpu_counter_sum+0x30/0x7c)
Jan  1 01:00:13 kernel: >>> [<c016d704>] (__percpu_counter_sum+0x30/0x7c) from [<bf5a6f38>] (ext4_commit_super+0xec/0x210 [ex        ]) from [<bf5ab3e8>] (ext4_fill_                                                            ..  c0c/0x2818 [ext4]) from [<c00cc050>] (get_sb_bdev+0x148/0x180)
Jan  1 01:00:13 kernel: >>> <                                8/0x180) from [<bf5a5838>] (ext4        [ext4]) from [<c00cb2c4>] (vfs_        )
Jan  1 01:00:13 kernel: >>> [<c00e2914>] (do_mount+0x15        0x1ac/0x1e4)
Jan  1 01:00:13 kernel: >>> [<c00416f8>] (di                                 (__do_kernel_fault+0x6c/0x8c)
Jan  1 01:00:13 kernel: [truncated] >>> [<bf5ab3e8>] (ext4_fi        sb_bdev+0x148/0x180) from [<bf5a
Jan  1 01:00:13 kernel: Hierarchical RCU implementation.
Jan  1 01:00:13 kernel: 	RCU-based detection of stalled CPUs is disabled.
Jan  1 01:00:13 kernel: 	Verbose stalled-CPUs detection is disabled.
Jan  1 01:00:13 syslog: module ledtrig-usbdev not found in modules.dep
Regards.
Use a Linux live CD to do a filesystem check (fsck).
great suggestion. I did, and it fixed all errors. Disk is back now on the router running again :D.
Thank you!
