AC68U http / https connection problem
FCM
Hello,
Sorry if this has been posted before, I wasn't able to locate a thread after a quick search of "AC68U https".
In the last few days my AC68U of 2.5 years has begun refusing connections at http://192.168.1.1.
Some changes that happened lately:
- I've switched to a fiber plan so I connect via a Huawei GPON which has its LAN port set-up in bridge mode by the Company (I don't have admin access to the GPON).
- I can't connect with Firefox from the PC, either http or https, but from Edge I can connect only https after I ignore the certificate error (Error Code: DLG_FLAGS_INVALID_CA).
- When I attempt to connect on http, I get either the "router settings have updated" page, which never refreshes, or "connection was reset".
- I can connect with no problems from my iPhone, which seems to use the "router.asus.com" url to locate the router.
- The router is also accesible via the Asus iOS companion app.
I've tried clearing the browser cache and internet history files, to no avail.
Any thoughts?
In the vein of this comic: https://xkcd.com/979/
Turns out that Bitdefender Free Edition was messing around with the access to the web interface. I decided to replace it with another antivirus solution and everything works now.
