AC68U Interface isn't working with Firefox
alistair
Hello,
right now I'm using the firmware 3.0.0.4.378.8258, but the same issue was present in (and since) the previous version (everything worked fine before). Every time I try to access the router's web interface with Firefox, I get the normal login screen at first, but after I've entered the password, I can only click a few things until the login screen shows up again and it wants me to enter my password/sign in again. Sometimes there's also an issue that not every element of the interface loads properly.
I was really hoping the new firmware might fix this, funny enough the changelog mentions compatibility fixes for IE, but not Firefox.
I can reliably make the sign in page pop up again, each time I try to switch between Status and 5GHz in Network Map/System Status - for example.
However, the interface still works exactly the way it should in Chrome, without that option I couldn't access my router anymore, let alone risk doing something as critical as an update.
Has anyone else similar (or even the same) issues with Firefox on this router and firmware? Any idea on what is causing this?
Thanks for reading!
Hello,
Thanks for reading!
Did you clear the Firefox's cache memory?
Yes, I did. No effect. I also cleared things like "Offline Web Content and User Data". None of that helped.
