ac68u is it bricked?
Cake
Anybody ever have after on/off or reset/power on ---> no power light led, no wifi, reset button does nothing, the usb 2.0 led on the front remains on even though I removed it.
The ac68u was plugged into a ups. Had a lightning show last night, then a mains outage, now I can't get it rebooted, or into recovery. I have searched and seen the post by rmerlin about a usb tty cable he used once. Not sure if it is worth it as 1 of the 4 lan ports is already blown out. I did put asus recovery onto a windows machine, no luck.
Is this EOL for my ac68u?
Probably. If the power LED fails to turn itself on, then either the AC adapter is fried, or the router is.
After a lightning hit - check the adapter first... and that's a low-cost approach... if you get no LED's on the device, it's either the adapter, or the DC input on the router itself, which in many cases, it's a fuse on the DC input side, and that's either a hard blow (common) or a soft blow (polyfuse) - I don't think Asus uses Polyfuses, but it doesn't hurt to unplug things for a day and see where it goes if the AC Adapter replacement doesn't fix things...
Polyfuses are darn cool... more info here -- https://en.wikipedia.org/wiki/Resettable_fuse
Thanks for the replies. It has power, some of the other led lights turn on.
Guess I will have to move on. ~sigh~
