AC68u loses internet connection after ~1 hr (ver. 380.59_0)
honkon
Hi guys,
First off, I hope this is the correct way to ask for help.
I recently moved and yesterday we had FIOS installed (previously no problem on Comcast). I went ahead and upgraded my 68u to 380.59_0, and after playing with some settings, did a factory reset and then the only change made was to setup the wireless networks.
Everything seems to work perfectly, except that my devices lose connectivity to the internet after about an hour of uptime, requiring a router restart (note: they remain able to connect to each other, and I can easily access the router admin site).
Any ideas?
Here's the most-recent log before resetting so I could get online and post this problem (just the end, so I didn't go over the post size limit):
Jul 31 20:00:23 kernel: Initializing USB Mass Storage driver...
Jul 31 20:00:23 kernel: usbcore: registered new interface driver usb-storage
Jul 31 20:00:23 kernel: USB Mass Storage support registered.
Jul 31 20:00:23 rc_service: udhcpc 547:notify_rc start_firewall
Jul 31 20:00:23 dnsmasq[444]: read /etc/hosts - 5 addresses
Jul 31 20:00:23 dnsmasq[444]: using nameserver 68.237.161.12#53 for domain verizon.net
Jul 31 20:00:23 dnsmasq[444]: using nameserver 71.252.0.12#53 for domain verizon.net
Jul 31 20:00:23 kernel: Tuxera FAT 12/16/32 driver version 3015.1.29.5_1 [Flags: R/W MODULE].
Jul 31 20:00:23 kernel: Built against headers 2.6.36.4brcmarm #1 SMP PREEMPT Wed Dec 2 11:17:39 CST 2015 arm
Jul 31 20:00:23 kernel: Running on kernel 2.6.36.4brcmarm #2 SMP PREEMPT Tue May 10 11:56:20 EDT 2016 armv7l
Jul 31 20:00:24 wan: finish adding multi routes
Jul 31 20:00:24 rc_service: udhcpc 547:notify_rc stop_upnp
Jul 31 20:00:24 rc_service: waitting "start_firewall" via udhcpc ...
Jul 31 20:00:24 kernel: Tuxera NTFS driver 3015.1.29.8_1 [Flags: R/W MODULE].
Jul 31 20:00:24 kernel: Tuxera HFS+ driver 3014.7.28
Jul 31 20:00:24 kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Jul 31 20:00:24 kernel: ehci_hcd 0000:00:0a.1: EHCI Host Controller
Jul 31 20:00:24 kernel: ehci_hcd 0000:00:0a.1: new USB bus registered, assigned bus number 1
Jul 31 20:00:24 kernel: ehci_hcd 0000:00:0a.1: irq 111, io mem 0x18021000
Jul 31 20:00:24 kernel: ehci_hcd 0000:00:0a.1: USB 0.0 started, EHCI 1.00
Jul 31 20:00:24 kernel: hub 1-0:1.0: USB hub found
Jul 31 20:00:24 kernel: hub 1-0:1.0: 2 ports detected
Jul 31 20:00:24 kernel: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Jul 31 20:00:24 kernel: ohci_hcd 0000:00:0a.0: OHCI Host Controller
Jul 31 20:00:24 kernel: ohci_hcd 0000:00:0a.0: new USB bus registered, assigned bus number 2
Jul 31 20:00:24 kernel: ohci_hcd 0000:00:0a.0: irq 111, io mem 0x18022000
Jul 31 20:00:24 kernel: hub 2-0:1.0: USB hub found
Jul 31 20:00:24 kernel: hub 2-0:1.0: 2 ports detected
Jul 31 20:00:24 kernel: usbcore: registered new interface driver usblp
Jul 31 20:00:24 kernel: usbcore: registered new interface driver asix
Jul 31 20:00:24 kernel: usbcore: registered new interface driver cdc_ether
Jul 31 20:00:24 kernel: usbcore: registered new interface driver rndis_host
Jul 31 20:00:24 kernel: cdc_ncm: 14-Mar-2012
Jul 31 20:00:24 kernel: usbcore: registered new interface driver cdc_ncm
Jul 31 20:00:24 kernel: usbcore: registered new interface driver cdc_wdm
Jul 31 20:00:24 kernel: usbcore: registered new interface driver qmi_wwan
Jul 31 20:00:24 kernel: cdc_mbim: loaded
Jul 31 20:00:24 kernel: usbcore: registered new interface driver cdc_mbim
Jul 31 20:00:25 WAN Connection: WAN was restored.
Jul 31 20:00:25 start_nat_rules: apply the nat_rules(/tmp/nat_rules_eth0_eth0)!
Jul 31 20:00:26 start_nat_rules: apply the nat_rules(/tmp/nat_rules_eth0_eth0)!
Jul 31 20:00:27 kernel: nf_conntrack_rtsp v0.6.21 loading
Jul 31 20:00:27 kernel: nf_nat_rtsp v0.6.21 loading
Jul 31 20:00:28 dnsmasq-dhcp[444]: DHCPDISCOVER(br0) b8:88:e3:fc:d5:c3
Jul 31 20:00:28 dnsmasq-dhcp[444]: DHCPOFFER(br0) 192.168.1.90 b8:88:e3:fc:d5:c3
Jul 31 20:00:28 dnsmasq-dhcp[444]: DHCPREQUEST(br0) 192.168.1.90 b8:88:e3:fc:d5:c3
Jul 31 20:00:28 dnsmasq-dhcp[444]: DHCPACK(br0) 192.168.1.90 b8:88:e3:fc:d5:c3 Bastian
Jul 31 20:00:28 rc_service: udhcpc 547:notify_rc start_upnp
Jul 31 20:00:28 rc_service: waitting "stop_upnp" via udhcpc ...
Jul 31 20:00:28 miniupnpd[495]: shutting down MiniUPnPd
Jul 31 20:00:28 dnsmasq-dhcp[444]: DHCPREQUEST(br0) 192.168.1.103 60:f8:1d:b7:e7:88
Jul 31 20:00:28 dnsmasq-dhcp[444]: DHCPACK(br0) 192.168.1.103 60:f8:1d:b7:e7:88 HonkonMacbookPro
Jul 31 20:00:28 dnsmasq-dhcp[444]: DHCPREQUEST(br0) 192.168.1.44 20:78:f0:b5:3c:65
Jul 31 20:00:28 dnsmasq-dhcp[444]: DHCPACK(br0) 192.168.1.44 20:78:f0:b5:3c:65 AlysonspleWatch
Jul 31 20:00:29 dhcp client: bound 71.176.227.145 via 71.176.227.1 during 7200 seconds.
Jul 31 20:00:29 miniupnpd[663]: HTTP listening on port 34198
Jul 31 20:00:29 miniupnpd[663]: Listening for NAT-PMP/PCP traffic on port 5351
Jul 31 20:00:30 ntp: start NTP update
Jun 14 08:25:05 rc_service: ntp 662:notify_rc restart_upnp
Jun 14 08:25:05 miniupnpd[663]: shutting down MiniUPnPd
Jun 14 08:25:05 miniupnpd[671]: HTTP listening on port 56357
Jun 14 08:25:05 miniupnpd[671]: Listening for NAT-PMP/PCP traffic on port 5351
Jun 14 08:25:06 rc_service: ntp 662:notify_rc restart_diskmon
Jun 14 08:25:06 disk_monitor: Finish
Jun 14 08:25:07 disk monitor: be idle
Jun 14 08:25:09 dnsmasq-dhcp[444]: DHCPREQUEST(br0) 192.168.1.116 00:61:71:cc:7f:88
Jun 14 08:25:09 dnsmasq-dhcp[444]: DHCPACK(br0) 192.168.1.116 00:61:71:cc:7f:88 Alysons-iPhone
Jun 14 08:25:18 dnsmasq-dhcp[444]: DHCPDISCOVER(br0) 10:ae:60:b5:a0:8a
Jun 14 08:25:18 dnsmasq-dhcp[444]: DHCPOFFER(br0) 192.168.1.32 10:ae:60:b5:a0:8a
Jun 14 08:25:19 dnsmasq-dhcp[444]: DHCPREQUEST(br0) 192.168.1.32 10:ae:60:b5:a0:8a
Jun 14 08:25:19 dnsmasq-dhcp[444]: DHCPACK(br0) 192.168.1.32 10:ae:60:b5:a0:8a
Jun 14 08:25:26 hour monitor: daemon is starting
Jun 14 08:25:31 dnsmasq-dhcp[444]: DHCPREQUEST(br0) 192.168.1.38 cc:20:e8:2a:f9:fd
Jun 14 08:25:31 dnsmasq-dhcp[444]: DHCPACK(br0) 192.168.1.38 cc:20:e8:2a:f9:fd Phones-Phone
Jun 14 08:25:35 crond[452]: time disparity of 458665 minutes detected
Jun 14 08:25:52 dnsmasq-dhcp[444]: DHCPREQUEST(br0) 192.168.1.50 24:a2:e1:10:35:93
Jun 14 08:25:52 dnsmasq-dhcp[444]: DHCPACK(br0) 192.168.1.50 24:a2:e1:10:35:93 Nicholass-iPad
Jun 14 08:34:12 dnsmasq-dhcp[444]: DHCPREQUEST(br0) 192.168.1.118 d0:03:4b:32:2b:32
Jun 14 08:34:12 dnsmasq-dhcp[444]: DHCPACK(br0) 192.168.1.118 d0:03:4b:32:2b:32 Apple-TV
Jun 14 08:41:19 dnsmasq-dhcp[444]: DHCPREQUEST(br0) 192.168.1.44 20:78:f0:b5:3c:65
Jun 14 08:41:19 dnsmasq-dhcp[444]: DHCPACK(br0) 192.168.1.44 20:78:f0:b5:3c:65 AlysonspleWatch
Jun 14 08:45:57 dnsmasq-dhcp[444]: DHCPREQUEST(br0) 192.168.1.118 d0:03:4b:32:2b:32
Jun 14 08:45:57 dnsmasq-dhcp[444]: DHCPACK(br0) 192.168.1.118 d0:03:4b:32:2b:32 Apple-TV
Jun 14 08:46:46 dnsmasq-dhcp[444]: DHCPDISCOVER(br0) d0:03:4b:32:2b:32
Jun 14 08:46:46 dnsmasq-dhcp[444]: DHCPOFFER(br0) 192.168.1.118 d0:03:4b:32:2b:32
Jun 14 08:46:47 dnsmasq-dhcp[444]: DHCPREQUEST(br0) 192.168.1.118 d0:03:4b:32:2b:32
Jun 14 08:46:47 dnsmasq-dhcp[444]: DHCPACK(br0) 192.168.1.118 d0:03:4b:32:2b:32 Apple-TV
Jun 14 08:51:15 dnsmasq-dhcp[444]: DHCPREQUEST(br0) 192.168.1.10 54:e4:3a:e3:df:28
Jun 14 08:51:15 dnsmasq-dhcp[444]: DHCPACK(br0) 192.168.1.10 54:e4:3a:e3:df:28 Allys-iPad-Mini
Jun 14 08:56:44 dnsmasq-dhcp[444]: DHCPREQUEST(br0) 192.168.1.118 d0:03:4b:32:2b:32
Jun 14 08:56:44 dnsmasq-dhcp[444]: DHCPACK(br0) 192.168.1.118 d0:03:4b:32:2b:32 Apple-TV
Jun 14 09:00:07 disk_monitor: Got SIGALRM...
Jun 14 09:03:14 dnsmasq-dhcp[444]: DHCPREQUEST(br0) 192.168.1.118 d0:03:4b:32:2b:32
Jun 14 09:03:14 dnsmasq-dhcp[444]: DHCPACK(br0) 192.168.1.118 d0:03:4b:32:2b:32 Apple-TV
Jun 14 09:06:07 dnsmasq-dhcp[444]: DHCPREQUEST(br0) 192.168.1.10 54:e4:3a:e3:df:28
Jun 14 09:06:07 dnsmasq-dhcp[444]: DHCPACK(br0) 192.168.1.10 54:e4:3a:e3:df:28 Allys-iPad-Mini
Jun 14 09:09:54 dnsmasq-dhcp[444]: DHCPREQUEST(br0) 192.168.1.50 24:a2:e1:10:35:93
Jun 14 09:09:54 dnsmasq-dhcp[444]: DHCPACK(br0) 192.168.1.50 24:a2:e1:10:35:93 Nicholass-iPad
Jun 14 09:18:03 dnsmasq-dhcp[444]: DHCPREQUEST(br0) 192.168.1.10 54:e4:3a:e3:df:28
Jun 14 09:18:03 dnsmasq-dhcp[444]: DHCPACK(br0) 192.168.1.10 54:e4:3a:e3:df:28 Allys-iPad-Mini
Jun 14 09:31:19 dnsmasq-dhcp[444]: DHCPREQUEST(br0) 192.168.1.10 54:e4:3a:e3:df:28
Jun 14 09:31:19 dnsmasq-dhcp[444]: DHCPACK(br0) 192.168.1.10 54:e4:3a:e3:df:28 Allys-iPad-Mini
This is just a standard boot log, it doesn't contain any info about the connection failure itself.
All I can see is that your ISP issues you with only a 1 hour lease, which seems rather short (24 hours is usually more common).
Wow, thanks for the quick reply Merlin!
I talked with Verizon and they said that FIOS always uses a lease like that and it shouldn't be a problem. Any other location where I can find an error or keep troubleshooting?
Try turning the modem off for 10 mins to fully reset the connection ISP-side, and try changing the DHCP frequency from Aggressive to Normal on the WAN page if it was set to Aggressive.
Beyond that, no other idea.
