Onemangang
Hi everyone.
A week ago I bought 2 x RT-AC68U, and it felt like christmas
But after a week of fiddeling around i am at a complete loss of what to do.
My problem is this:
The first router is set up normally, with a ssid on each band, Asus/Asus_5G.
The second router is connected as mediabridge to the first on the 5G band.
Both routers have clients on the lan ports in gigabit mode, and router one
also services our phones, laptops and tablets on wireless 2.4GHz G+N.
Copying files between computers over the mediabridge gives me speeds
around 50MB/sec at a link speed of 702Mbit/sec. That is quite ok.
The first router also has a usb3 drive attached to it's usb3 port.
This is where the trouble starts for wireless 5G.
If i try to read any data from that usb3 drive over the media bridge,
i get at best 3MB/sec, yes 3 megabyte, and the copy seems sluggish.
Writing to it can sometimes be a little faster for some reason.
If I read data from it on one of my computers directly attached to the
gigabit ports, I can get up to around 52MB/sec, it varies a little.
But any traffic on the 5G band is a no go, as long as the usb3 disk
is working.
My laptops (2.4GHz/N) will all read from/write to that usb3 disk with
around 13MB/sec. Plugging the same usb3 disk in a computer gives
speeds of around 105-108MB/sec. So the drive is working.
So basically the usb3 port kills my 5G, wich is pretty much the opposite of
what i have read about interferrence on the 2.4GHz band and usb3.
Also, setting the "interferrence" setting back to activated does'nt do
anything for me. I have to dismount the usb3 drive and do a full reset
with the resessed button on the back to get it back to running in usb2
mode again.
I spoke with asus support in Sweden ( I live in Denmark ) and they where
pussled. They suggested to get my money back, for surely those two
devices are buggy. But what are the changes for that heh?
I then tried to switch the two routers to change roles, but i got the
exact same behavior, speed and everything.
I have also updated to the latest firmware on them both, and i even
tried Merlins .39 build today, still the same issue remains.
I really like those routers. Should i keep them and only use usb2 mode?
The usb3 port was the important factor for me, and now i cant use it.
On a side note:
I asked asus support if it was okay to try a custom firmware to try
and fix the problem, without voiding warranty. That was actually ok.
I would not void my warranty as long as any problems where not
caused by that firmware.
When both usb ports are in usb2 mode, i can read/write with around
28 MB/sec to the disk(s).
My usb3 drives are all Medion 2½ inch using the "asmt 2105" controller.
The cables are quite thick wich i guess means they are shielded ok.
Anyway, I still have a few days left before its too late to return them.
If anyone has any suggestions, I am all ears.
I'd really like to keep these routers, but that usb3 thing is a killer for me.
Regards
My problem is this:
is working.
mode again.
On a side note:
Regards
