AC68U - OpenVPN regularly dropping
Evansgo
I have an AC68 with firmware 378.53 and have never tried this before so this could easily be a simple mistake. I set up the VPN specifically to give me a UK IP and specifically OPENVPN as I needed the individual IP routing capability (fantastic!) not for security.
It all works fine for a while, but if the VPN is not used it drops out frequently, I have amended the Poll Interval to keep it alive, but really wanted to see if I could fix it properly.
Here is a snippet of the log, hopefully where the issue is....
Would someone please take a look for me and see if it is anything obvious?
May 19 12:20:01 crond[486]: crond: USER xxxx pid 23066 cmd service start_vpnclient1
May 19 12:20:02 rc_service: service 23067:notify_rc start_vpnclient1
May 19 12:20:02 syslog: VPN_LOG_NOTE: 75: VPN Client 1 already running...
May 19 12:20:06 openvpn[22513]: ERROR: could not read Auth username from stdin
May 19 12:20:06 openvpn[22513]: Exiting due to fatal error
May 19 12:20:06 openvpn[22513]: vpnrouting.sh tun11 1500 1558 xx.xxx.49.3 255.255.255.192 init
May 19 12:20:06 openvpn-routing: Configuring policy rules for tun11
May 19 12:20:07 openvpn-routing: Removing rule 32759 from routing policy
May 19 12:20:07 openvpn-routing: Removing rule 32760 from routing policy
May 19 12:20:07 openvpn-routing: Removing rule 32761 from routing policy
May 19 12:20:07 openvpn-routing: Removing rule 32762 from routing policy
May 19 12:20:07 openvpn-routing: Removing rule 32763 from routing policy
May 19 12:20:07 openvpn-routing: Removing rule 32764 from routing policy
May 19 12:20:07 openvpn-routing: Removing rule 32765 from routing policy
May 19 12:20:07 openvpn-routing: Completed routing policy configuration
May 19 12:20:07 openvpn[22513]: ERROR: Linux route delete command failed: external program exited with error status: 2
May 19 12:20:07 openvpn[22513]: /usr/sbin/ip addr del dev tun11 xx.xxx.49.3/26
May 19 12:20:07 openvpn[22513]: updown.sh tun11 1500 1558 xx.xxx.49.3 255.255.255.192 init
May 19 12:20:07 rc_service: service 23123:notify_rc updateresolv
May 19 12:20:07 dnsmasq[22575]: read /etc/hosts - 5 addresses
May 19 12:20:07 dnsmasq[22575]: read /etc/hosts.dnsmasq - 3 addresses
May 19 12:20:07 dnsmasq-dhcp[22575]: read /etc/ethers - 7 addresses
May 19 12:20:07 dnsmasq[22575]: using nameserver 4.4.4.4#53 for domain local
May 19 12:20:07 dnsmasq[22575]: using nameserver 8.8.8.8#53 for domain local
May 19 12:20:08 rc_service: service 23125:notify_rc restart_dnsmasq
May 19 12:20:08 dnsmasq[22575]: exiting on receipt of SIGTERM
May 19 12:20:09 dnsmasq[23134]: started, version 2.73rc1 cachesize 1500
May 19 12:20:09 dnsmasq[23134]: warning: interface ppp1* does not currently exist
May 19 12:20:09 dnsmasq[23134]: asynchronous logging enabled, queue limit is 5 messages
May 19 12:20:09 dnsmasq-dhcp[23134]: DHCP, IP range 192.168.x.101 -- 192.168.x.200, lease time 1d
May 19 12:20:09 dnsmasq[23134]: read /etc/hosts - 5 addresses
May 19 12:20:09 dnsmasq[23134]: read /etc/hosts.dnsmasq - 3 addresses
May 19 12:20:09 dnsmasq-dhcp[23134]: read /etc/ethers - 7 addresses
May 19 12:20:09 dnsmasq[23134]: using nameserver 4.4.4.4#53 for domain local
May 19 12:20:09 dnsmasq[23134]: using nameserver 8.8.8.8#53 for domain local
Corrupt config?
Also, when you get a chance, check your local DNS servers - looks like you're using Google PublicDNS - and those are at 8.8.8.8 and 8.8.4.4 for IPv4...
https://developers.google.com/speed/public-dns/
Thanks for that, I spotted the DNS just after I posted it and have now changed it. I did wonder about the config, but it works every time I manually connect so thought it wouldn't be that. Also I did find that thread thanks, but it didn't help me, probably due to a lack of knowledge....
I tried messing about with the custom commands but as I'm doing it by googling each line, its a bit haphazard :)
In case it makes a difference I'm using pureVPN and set it up with their web site help. The custom list is:-
mute 20
float
route-method exe
route-delay 2
auth-retry interact
explicit-exit-notify 2
ifconfig-nowarn
auth-nocache
