AC68u overheating ?
Wolfrus
its 1 year old ,CFE Unlocked 316mw power, when router idle temps on cpu 85-88 chips are 55-57 , when im downloading over 5ghz 30mb/s and 10mb/s over 2.4 - cpu 98-106 , chips 70-75 i think cpu is overheating :(
What i can do to these ? mb change thermal pad to bigger or use thermal compound ?
Or its normal and nothing to do?
Thanks!
turn down your transmission power, your overheating your radios which is probably influencing your cpu temp.
+1, see if you can get by without raising TX power. Also if you feel like it you can redo heat
sinking paste treatment for all heat sinks good quality paste.
