AC68U WAN disconnets every 5-10min
trueinsider
Since I bought that router I'm experiencing disconnects from internet every 5-10 min. I tried to research this problem but to no avail. Everything is fine if I connect my old D-Link DIR-615.
FW version: I tried last stock and last Merlin .40 and .39 (current)
HW acceleration: OFF
This is debug log of what happens:
Mar 16 05:56:06 WAN Connection: WAN was restored.
Mar 16 05:56:07 dnsmasq[11006]: exiting on receipt of SIGTERM
Mar 16 05:56:07 dnsmasq[11041]: started, version 2.68 cachesize 1500
Mar 16 05:56:07 dnsmasq[11041]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth
Mar 16 05:56:07 dnsmasq[11041]: asynchronous logging enabled, queue limit is 5 messages
Mar 16 05:56:07 dnsmasq-dhcp[11041]: DHCP, IP range 192.168.1.2 -- 192.168.1.254, lease time 1d
Mar 16 05:56:07 dnsmasq-dhcp[11041]: DHCP, sockets bound exclusively to interface br0
Mar 16 05:56:07 dnsmasq[11041]: read /etc/hosts - 5 addresses
Mar 16 05:56:07 dnsmasq[11041]: using nameserver 212.33.224.133#53
Mar 16 05:56:07 dnsmasq[11041]: using nameserver 212.33.225.212#53
Mar 16 05:56:08 rc_service: ip-up 11021:notify_rc stop_upnp
Mar 16 05:56:08 rc_service: ip-up 11021:notify_rc start_upnp
Mar 16 05:56:08 rc_service: waitting "stop_upnp" via ip-up ...
Mar 16 05:56:09 pppd[10681]: rcvd [IPV6CP TermReq id=0x4e]
Mar 16 05:56:09 pppd[10681]: Unsupported protocol 'IPv6 Control Protocol' (0x8057) received
Mar 16 05:56:09 pppd[10681]: sent [LCP ProtRej id=0x8 80 57 05 4e 00 04]
Mar 16 05:56:09 pppd[10681]: Script /tmp/ppp/ip-up finished (pid 11021), status = 0x0
Mar 16 05:56:10 miniupnpd[11063]: HTTP listening on port 46941
Mar 16 05:56:10 miniupnpd[11063]: Listening for NAT-PMP traffic on port 5351
[B]* AND HERE GOES DISCONNECT *[/B]
Mar 16 06:05:52 pppd[10681]: rcvd [LCP TermReq id=0x5f]
Mar 16 06:05:52 pppd[10681]: LCP terminated by peer
Mar 16 06:05:52 pppd[10681]: Connect time 9.8 minutes.
Mar 16 06:05:52 pppd[10681]: Sent 9139985 bytes, received 4288703 bytes.
Mar 16 06:05:52 miniupnpd[11063]: Failed to get IP for interface ppp0
Mar 16 06:05:52 miniupnpd[11063]: SendNATPMPPublicAddressChangeNotification: cannot get public IP address, stopping
Mar 16 06:05:52 pppd[10681]: Script /tmp/ppp/ip-down started (pid 11546)
Mar 16 06:05:52 pppd[10681]: sent [LCP TermAck id=0x5f]
Mar 16 06:05:52 dnsmasq[11041]: read /etc/hosts - 5 addresses
Mar 16 06:05:52 dnsmasq[11041]: using nameserver 212.33.224.133#53
Mar 16 06:05:52 dnsmasq[11041]: using nameserver 212.33.225.212#53
Mar 16 06:05:52 pppd[10681]: Script /tmp/ppp/ip-down finished (pid 11546), status = 0x0
Mar 16 06:05:55 WAN Connection: Fail to connect with some issues.
Mar 16 06:05:55 stop_nat_rules: apply the redirect_rules!
Mar 16 06:05:55 dnsmasq[11041]: exiting on receipt of SIGTERM
Mar 16 06:05:55 pppd[10681]: Connection terminated.
Mar 16 06:05:55 pppd[10681]: Sent PADT
Mar 16 06:05:55 pppd[10681]: Modem hangup
Mar 16 06:05:55 dnsmasq[11556]: started, version 2.68 cachesize 1500
Mar 16 06:05:55 dnsmasq[11556]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth
Mar 16 06:05:55 dnsmasq[11556]: asynchronous logging enabled, queue limit is 5 messages
Mar 16 06:05:55 dnsmasq-dhcp[11556]: DHCP, IP range 192.168.1.2 -- 192.168.1.254, lease time 1d
Mar 16 06:05:55 dnsmasq-dhcp[11556]: DHCP, sockets bound exclusively to interface br0
Mar 16 06:05:55 dnsmasq[11556]: read /etc/hosts - 5 addresses
Mar 16 06:05:55 dnsmasq[11556]: using nameserver 212.33.224.133#53
Mar 16 06:05:55 dnsmasq[11556]: using nameserver 212.33.225.212#53
[B]* CONNECTING BACK *[/B]
Mar 16 06:06:05 pppd[10681]: PADS: Service-Name: ''
Mar 16 06:06:05 pppd[10681]: PPP session is 576 (0x240)
Mar 16 06:06:05 pppd[10681]: Connected to a0:f3:e4:04:6d:4c via interface eth0
Mar 16 06:06:05 pppd[10681]: using channel 31
Mar 16 06:06:05 pppd[10681]: Using interface ppp0
Mar 16 06:06:05 pppd[10681]: Connect: ppp0 <--> eth0
Mar 16 06:06:05 pppd[10681]: sent [LCP ConfReq id=0x9 <mru 1492> <magic 0xb9b4076>]
Mar 16 06:06:05 pppd[10681]: rcvd [LCP ConfReq id=0xca <mru 1492> <auth chap MD5> <magic 0x43e399df>]
Mar 16 06:06:05 pppd[10681]: sent [LCP ConfAck id=0xca <mru 1492> <auth chap MD5> <magic 0x43e399df>]
Mar 16 06:06:05 pppd[10681]: rcvd [LCP ConfAck id=0x9 <mru 1492> <magic 0xb9b4076>]
Mar 16 06:06:05 pppd[10681]: sent [LCP EchoReq id=0x0 magic=0xb9b4076]
Mar 16 06:06:05 pppd[10681]: rcvd [CHAP Challenge id=0x1 <43085607d2761e2f83c5c332ecb8069829ac600a9119b5ef2dae1545ea25f5ae2dcbb57f42d32ec519f1f8>, name = "bsr03-perm"]
Mar 16 06:06:05 pppd[10681]: sent [CHAP Response id=0x1 <c11b58ce53420a9292fdc15eb000d570>, name = "trueinsider"]
Mar 16 06:06:05 pppd[10681]: rcvd [LCP EchoRep id=0x0 magic=0x43e399df]
Mar 16 06:06:05 pppd[10681]: rcvd [CHAP Success id=0x1 "CHAP authentication success"]
Mar 16 06:06:05 pppd[10681]: CHAP authentication succeeded: CHAP authentication success
Mar 16 06:06:05 pppd[10681]: peer from calling number A0:F3:E4:04:6D:4C authorized
Mar 16 06:06:05 pppd[10681]: sent [IPCP ConfReq id=0x5 <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns2 0.0.0.0>]
Mar 16 06:06:05 pppd[10681]: rcvd [IPV6CP ConfReq id=0x31 <addr fe80::a2f3:e4ff:fe04:6c01>]
Mar 16 06:06:05 pppd[10681]: Unsupported protocol 'IPv6 Control Protocol' (0x8057) received
Mar 16 06:06:05 pppd[10681]: sent [LCP ProtRej id=0xa 80 57 01 31 00 0e 01 0a a2 f3 e4 ff fe 04 6c 01]
Mar 16 06:06:05 pppd[10681]: rcvd [IPCP ConfReq id=0x17 <addr 212.33.234.72>]
Mar 16 06:06:05 pppd[10681]: sent [IPCP ConfAck id=0x17 <addr 212.33.234.72>]
Mar 16 06:06:05 pppd[10681]: rcvd [IPCP ConfNak id=0x5 <addr 37.112.29.110> <ms-dns1 212.33.225.212> <ms-dns2 212.33.224.133>]
Mar 16 06:06:05 pppd[10681]: sent [IPCP ConfReq id=0x6 <addr 37.112.29.110> <ms-dns1 212.33.225.212> <ms-dns2 212.33.224.133>]
Mar 16 06:06:05 pppd[10681]: rcvd [IPV6CP TermReq id=0x32]
Mar 16 06:06:05 pppd[10681]: sent [LCP ProtRej id=0xb 80 57 05 32 00 04]
Mar 16 06:06:05 pppd[10681]: rcvd [IPCP ConfAck id=0x6 <addr 37.112.29.110> <ms-dns1 212.33.225.212> <ms-dns2 212.33.224.133>]
Mar 16 06:06:05 miniupnpd[11063]: Failed to get IP for interface ppp0
Mar 16 06:06:05 miniupnpd[11063]: SendNATPMPPublicAddressChangeNotification: cannot get public IP address, stopping
Mar 16 06:06:05 pppd[10681]: Script /tmp/ppp/ip-pre-up started (pid 11565)
Mar 16 06:06:05 pppd[10681]: Script /tmp/ppp/ip-pre-up finished (pid 11565), status = 0x0
Mar 16 06:06:05 pppd[10681]: local  IP address 37.112.29.110
Mar 16 06:06:05 pppd[10681]: remote IP address 212.33.234.72
Mar 16 06:06:05 pppd[10681]: primary   DNS address 212.33.225.212
Mar 16 06:06:05 pppd[10681]: secondary DNS address 212.33.224.133
Mar 16 06:06:05 pppd[10681]: Script /tmp/ppp/ip-up started (pid 11566)
Mar 16 06:06:06 miniupnpd[11063]: ioctl(s, SIOCGIFADDR, ...): Cannot assign requested address
Mar 16 06:06:06 miniupnpd[11063]: Failed to get IP for interface ppp0
Mar 16 06:06:06 miniupnpd[11063]: SendNATPMPPublicAddressChangeNotification: cannot get public IP address, stopping
Mar 16 06:06:06 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Mar 16 06:06:06 dnsmasq[11556]: read /etc/hosts - 5 addresses
Mar 16 06:06:06 dnsmasq[11556]: using nameserver 212.33.224.133#53
Mar 16 06:06:06 dnsmasq[11556]: using nameserver 212.33.225.212#53
Mar 16 06:06:06 dnsmasq[11556]: exiting on receipt of SIGTERM
Mar 16 06:06:06 dnsmasq[11586]: started, version 2.68 cachesize 1500
Mar 16 06:06:06 dnsmasq[11586]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth
Mar 16 06:06:06 dnsmasq[11586]: asynchronous logging enabled, queue limit is 5 messages
Mar 16 06:06:06 dnsmasq-dhcp[11586]: DHCP, IP range 192.168.1.2 -- 192.168.1.254, lease time 1d
Mar 16 06:06:06 dnsmasq-dhcp[11586]: DHCP, sockets bound exclusively to interface br0
Mar 16 06:06:06 dnsmasq[11586]: read /etc/hosts - 5 addresses
Mar 16 06:06:06 dnsmasq[11586]: using nameserver 212.33.224.133#53
Mar 16 06:06:06 dnsmasq[11586]: using nameserver 212.33.225.212#53
Mar 16 06:06:08 rc_service: ip-up 11566:notify_rc stop_upnp
Mar 16 06:06:08 rc_service: ip-up 11566:notify_rc start_upnp
Mar 16 06:06:08 rc_service: waitting "stop_upnp" via ip-up ...
Mar 16 06:06:08 pppd[10681]: rcvd [IPV6CP TermReq id=0x33]
Mar 16 06:06:08 pppd[10681]: Unsupported protocol 'IPv6 Control Protocol' (0x8057) received
Mar 16 06:06:08 pppd[10681]: sent [LCP ProtRej id=0xc 80 57 05 33 00 04]
Mar 16 06:06:09 pppd[10681]: Script /tmp/ppp/ip-up finished (pid 11566), status = 0x0
Mar 16 06:06:09 miniupnpd[11607]: HTTP listening on port 40413
Mar 16 06:06:09 miniupnpd[11607]: Listening for NAT-PMP traffic on port 5351
Mar 16 06:06:10 WAN Connection: WAN was restored.
So, rcvd [LCP TermReq id=0x5f] means termination request sent from my provider? Or that router tells provider that it will now disconnect? What exactly is 0x5f? Why is it happening out of blue?
Go in to WAN settings, and change the last option from Aggressive to Normal.
This has been discussed dozens of times on this forum.
Switched off router for the night and then it worked without disconnects for 440 minutes. But after that again...
