Hi All
Newbie here so I'd appreciate some advice please. I'm in the process of changing ISP meaning I lose my old ISP's (rather flaky but better coverage than single ISP provided router) mesh wifi solution so I need a good quality router to try and retain as much coverage as possible. The house is about 2,000sqft over 2 floors plus loft above that needs signal, but with solid walls throughout I've previously struggled to get signal to all corners of the house with a single ISP provided router so I'm hoping I'll have more success with a better quality product.
My first question is therefore relating to WiFi coverage, I think other threads have answered this but am I right in saying the AC86 should give slightly better speed at range than the AC68 but in terms of coverage there's not a lot between them?
Secondly, I understand from other threads here that the AC86 blows most things out of the water when it comes to OpenVPN server performance including the AC68. However, given I only need it for remote admin into the home network to fix issues for my wife whilst at work etc and given the 52/10 speed of the connection we have I'm unsure if I'd see any significant benefit with an AC86 over a 68?
Finally I read somewhere that the Asus VPN implementation holds onto the router's IP and doesn't support the use of a DDNS service so really needs a static IP from the ISP to reliably connect to the VPN (which I can't get)? Is this actually an issue or can the VPN server now cope with that so I can always connect to the VPN even if the IP changes occasionally?
To conclude I've pretty much decided on Asus over Netgear but I'm trying to determine whether the AC86 is worth the extra ~£65 (£135 against £200 in the UK) over the AC68 for what I need it to do. My first thought is the AC86 is a newer chipset and more powerful with better WiFi specs so would be the best option as the price isn't a massive showstopper but if VPN speed is a non issue I'm wondering if I might actually be better going for an AC68 and putting the £65 saved towards a second AC68 to set up AiMesh if I find I need it?
thanks all
thanks all
