AC86U EU AC Adapter
m1nkeh
Hey,
I have an AC86U that I bought over from the UK to Europe a few years ago and would like to replace the adapter with an EU model.
Could someone that has one (with the two-prong EU plug) please give me some clues on the search terms in order to locate one? What does it say on yours?
I can see AD891M21 on the adapter itself, but using this as a search term doesn't really give me much as it seems to be a general 19V 1.75A affair
Failing that I guess I'll call ASUS tomorrow
Thanks in advance!
Hey,
Thanks in advance!
Look at the input specs for the adaptor -- most of them already accept 240VAC so you would only need to change the plug or use a physical plug adaptor.
^ This.
The UK power adapters are multi-voltage and can be used worldwide. Only the mains plug is different.
I probably should have explained, sorry, but the AC adapter is frayed and I wanted to replace it with one that didn't need an adapter any longer :)
Hey,
Thanks in advance!
You have to follow this Condition.
1. 19V.
2. 1.75A or Above.
Solution.
1. https://www.aliexpress.com/i/3256801170647821.html?gatewayAdapt=4itemAdapt
2. https://www.amazon.de/s?k=uk+to+eu+plug&crid=2XR8SOBPVX5HH&sprefix=uk+to+eu+plug,aps,324&ref=nb_sb_noss_1
3. Buy an ASUS laptop EU adapter. 19V. 1.75 or above. You have to make it sure. Because there are a lot of fake Chinese ASUS adapters.
4. Buy a 3rd party adapter.
5. Buy a new router.
I saw that one on AliExpress... is it legit?
Never ordered anything from Ali before... isn't it all just knock-off stuff? :D
Edit: Considering option #5 tbh
ASUS laptop adapters have same diameter. 3rd party adapters which support certain routers have same diameter too.
Agreed. But still check -- some older ASUS routers used a skinnier plug. And my ASUS laptop supply wouldn't help at all -- it's a USB-C.
Because many manufacturers are using USB PD adapters these days. The cable is not that flexible. I feel so strange every time I use it.:eek: And mine shares Thunderbolt, USB and PD with same ports. I hate it.:mad:
