accel-ppp (l2tp/ppp/ppoe) software on ASUSWRT-Merlin
chiwalfrm
I wanted to replace the built-in PPTP VPN with a L2TP software instead because PPTP can be cracked within a day.
http://www.computerworld.com/s/arti...ck_widely_used_PPTP_encryption_in_under_a_day
Browing the Entware list of packages, I found "accel-ppp".
accel-ppp - 1.7.3-1 - The ACCEL-PPP is high performance PPTP/L2TP/PPPoE server for Linux. Userspace daemon has its own PPP implementation, so it does not uses pppd and one process (multi-threaded) manages all connections.
Installing it on ASUSWRT-Merlin went without a hitch.
Using the minimal config file posted at their website:
http://sourceforge.net/apps/trac/accel-ppp/wiki/ConfigSOHO
I started it up and in the syslog, I see:
Sep 18 09:40:07 RT-N16 accel-pppd: failed to load pptp kernel module
Sep 18 09:40:07 RT-N16 accel-pppd: failed to load pppoe kernel module
Sep 18 09:40:07 RT-N16 accel-pppd: unable to load l2tp kernel module
Sep 18 09:40:07 RT-N16 accel-pppd: accel-ppp version 1.7.3
Any idea what is wrong? I searched this forum for "accel-ppp" and found nothing. I have already disabled the built-in PPTP daemon by setting it to 'No'.
The command to start it is:
/tmp/mnt/Entware/entware/sbin/accel-pppd -d -c /tmp/mnt/Entware/entware/etc/accel-ppp.conf
Thank you.
Why not use OpenVPN? It's far more secure, and is integrated into the firmware.
Sure, it's highly secure, but it's also a pain for newbies to set up. There are assumptions about familiarity with security terms and concepts that the average hobbyist doesn't know.
I tried it once between a Mac and a PC. It took me several hours on and off to get it right.
L2TP is reasonably secure while still being fairly simple to deploy.
you're either missing needed kernel modules
or the modules install (likely from entware)
are not compatible with your router
