Actiontec routing to external IP
registering
[Moved from Articles]
I have a specific situation in which I need to do the following: route inbound connections on a specific port back to another external IP address. So in essence, I am looking to route (proxy?) between two external hosts.
I am using an Actiontec MI 424-WR and have full access to all routing functions through telnet.
My situation is that I have traffic coming in to my router that used to be port forwarded to a server on the LAN. That server has been moved to another public IP, but for a number of reasons, I need to clients to continue to communicate with the old IP address:port and route the connection over to the new address. There are no servers behind the actiontec anymore to act as a real proxy server, so I need to do it just with routing rules. I think this is more a routing question thatn an ActionTec question as it seems capable enough.
I have tried a number of different set-ups using port forwrading to a VLAN and then trying to set up routing rules back out to the external IP address but have had no luck. I have seen references to the fact that this router can indeed reroute traffic out the same interface, but am at a loss.
Other ideas I have considered:
- set up a VPN from the Actiontec to the remote server.
- Play with static routing rules
Any advice (or even explicit reasons why this wont work) are very welcome.
