Addons tab completely gone?
Sptz
Hi all,
384.17 on AC68U. The addons page used to be there at the bottom of the list and used to show both spdmerlin and connmon. Now it's gone out of nowhere, I can't access both these addons. Anyone knows of a way to restore it?
Thanks!
Does a reboot help?
What version of RMerlin firmware are you on? What version of amtm are you using?
I am following as I have had this happen with the .16 release. Had to clean install to get it back. Reboot was no help. In my case, just spdmerlin was installed.
same exact thing happened to me, after updating ntpmerlin
Any messages in syslog, particularly messages about NTP not sync'd or Entware not ready?
Does running
ntpmerlin startup
yield any errors?
Does running
ntpmerlin startup
yield any errors?
yields no errors. and the web ui page is back.
did same for connmon, and connmon is back too
thanks
Does running
ntpmerlin startup
yield any errors?
Reboot didn't help. Just did spdmerlin startup and it mounted to addons which then showed up. I wonder why it's not automounting?
There should be syslog messages indicating why. Feel free to PM me a full log with a reboot in it
