Advice to Add node to ax6000
chrisbati
Hello,
I have an aimesh network with Asus ax6000 as master and rt-ax86u as first node (connect with 2.5g port).
I'm very happy with the quality of the network wesh.
I would like to Add one or two node and i'm looking for advice for the cheapest solution but with the same level of quality.
Thanks in advance for any advice
Kind regards
Chrisbati
Cheap and quality do not always play well together. Do you really need more WIFI? Ethernet or WIFI backhaul?
An AX86S would be a good starting point.
I need more wifi range with ethernet backhaul!
I was thinking adding a second ax86u, but I don't need most of the features.
Then I looked at the Asus zen wifi, but not sure if I Can use the 2.5g as backhaule and not sure if they are fully compatible with my aimesh network.
I will have a look at AX86s, thanks for the advice.
