After changing IP on my PC, GUI's RT-N66U locked out.
Fizzy_Amp
Due of my connection has very bad at last night, i decide to change my IP address overnight. But the router won't read my IP to access their GUI, now locked out. I received a error page,"Settings have been updated. Web page will now refresh. Changes have been made to the IP address or port number. You will now be disconnected from RT-N66U. To access the settings of RT-N66U, reconnect to the wireless network and use the updated IP address and port number." I believe my router can access IP is 192.168.1.2 before i changed it, right now my new IP is 192.168.1.69.
run "Discovery.exe" to find the new IP of your router. It came with your router on dvd/cd or gt it here
http://support.asus.com/download.as....b1)&p=11&s=2&os=29&hashedid=pzkfhlmrgwzvroxt
What's a next?
I read router's IP is 192.168.1.1 (Default).
EDIT: I tries to reinstall from software utility, it said "Please check the wired connection between your computer and the router then try again." I'm really so frustrating now..
EDIT 2: Cheers, i just using static ip address, it worked. (I know this is very easy step, but i'm a novice programmer. Otherwise, my other problem has not over: http://bit.ly/1drwQ1t)
