AGH v0.107.26 not starting...
PxP
Rebooted my AX86 manually and AdGuardHome v0.107.26 is not starting.
Can`t enter WebUI anymore
Can`t uninstall by using amtm>ASUSWRT-MERLIN ADGUARDHOME INSTALLER (after pressing y(es) nothing happens)...
I`m not using any other scripts.
How to wipeout all (besides Merlin firmware of coz) - and install AGH fresh?
do killall -9 AdGuardHome S99AdGuardHome from the command line, and then try to uninstall.
You need to make sure you have entware installed VIA amtm before attempting to install adguardhome.
Adguardhome requirements
  1. Jffs scripts must be enabled on Asuswrt Merlin firmware
  2. AdGuardhome requires a reasonable size storage (50gb or more preferred).
  3. AdGuardHome requires Entware repository to be installed via AMTM before attempting to be installed.
  4. Entware Repository (and/or flash storage) must not be corrupt or broken.
@RMerlin
These two topics are related
Please check for more details.
