Yes.Will AI mesh work if one router is using Merlin firmware and the other is using standard ASUS firmware
Will AI mesh work if one router is using Merlin firmware and the other is using standard ASUS firmware? I’m looking at the GT6 mesh routers, which don’t currently have Merlin support and expanding with my preexisting ASUS routers that run Merlin.
well, my ax86u is using merlinware's 388 and the meshed ac86u is using stockware at 386. so far, ok except the ac86u's 2.4 radio has very poor throughput although showing a strong connection. if the mesh code is "locked," how can we be aware of any changes?Generally the recommendation is run Merlin on the main router and factory firmware on the nodes. Just keep them on the same code base like 386 or 388 on all (not technically a requirement but a best practice).
that makes sense. but damnit! now i'm gonna have to do break it out and do a standalone test. with the exception of hdd, not sure i've ever seen a hdw problem in some 40+ yrs. still, a good point as i'm not sure what else is left.If an AC86U 2.4 radio is not working well, I'd suspect hardware failure.
OE
Welcome To SNBForums
