Aimesh 68u Node disconnecting
ecantona9
I have an Aimesh setup with the main router being an AC3100 with an AC68U setup as the node in my basement. It is on a wireless backhaul. Connection is showing as great. RSSI=-56dbm and using the Merlin Alpha 3 firmware that just dropped, but I've been on Merlin 384.19 before. For some reason the node goes down and disconnects for about 2 minutes a few times each day but it comes right back up. I've set fixed channels for each of the bands and turned off Airtime Fairness.
Below is the system log during the time period of the disconnect.
Nov 15 12:39:51 syslog: wlceventd_proc_event(491): eth1: Disassoc 6E:30:BC:D6:42:57, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Nov 15 12:39:51 syslog: wlceventd_proc_event(510): eth1: Auth 6E:30:BC:D6:42:57, status: Successful (0)
Nov 15 12:39:51 syslog: wlceventd_proc_event(520): eth1: ReAssoc 6E:30:BC:D6:42:57, status: Successful (0)
Nov 15 12:39:51 kernel: br0: received packet on vlan1 with own address as source address
Nov 15 12:40:10 syslog: wlceventd_proc_event(510): eth2: Auth 04:03:D6:2A:35:42, status: Successful (0)
Nov 15 12:40:10 syslog: wlceventd_proc_event(539): eth2: Assoc 04:03:D6:2A:35:42, status: Successful (0)
Nov 15 12:40:10 dnsmasq-dhcp[416]: DHCPDISCOVER(br0) 04:03:d6:2a:35:42
Nov 15 12:40:10 dnsmasq-dhcp[416]: DHCPOFFER(br0) 192.168.2.245 04:03:d6:2a:35:42
Nov 15 12:40:10 dnsmasq-dhcp[416]: DHCPREQUEST(br0) 192.168.2.245 04:03:d6:2a:35:42
Nov 15 12:40:10 dnsmasq-dhcp[416]: DHCPACK(br0) 192.168.2.245 04:03:d6:2a:35:42
Nov 15 12:40:22 syslog: wlceventd_proc_event(510): eth1: Auth 08:84:9D:D3:3A:90, status: Successful (0)
Nov 15 12:40:23 syslog: wlceventd_proc_event(539): eth1: Assoc 08:84:9D:D3:3A:90, status: Successful (0)
Nov 15 12:40:23 dnsmasq-dhcp[416]: DHCPDISCOVER(br0) 08:84:9d:d3:3a:90
Nov 15 12:40:23 dnsmasq-dhcp[416]: DHCPOFFER(br0) 192.168.2.9 08:84:9d:d3:3a:90
Nov 15 12:40:23 dnsmasq-dhcp[416]: DHCPREQUEST(br0) 192.168.2.9 08:84:9d:d3:3a:90
Nov 15 12:40:23 dnsmasq-dhcp[416]: DHCPACK(br0) 192.168.2.9 08:84:9d:d3:3a:90 amazon-b760d3f8d
Nov 15 12:40:23 kernel: 08:84:9D:D3:3A:90 not mesh client, can't update it's ip
Has anyone had this problem and been able to correct it?
