AIMESH and Astrill applets?
byyuan
I have 2 Asus Routers, 1 is Merlined, the other one is not capable. Can I still AIMesh?
I'm using Astrill on Router 1, if I AIMeshed, would both network still under Astrill? thank you
Mr Tvardovsky
Check this out:
By the way, you should be able to flash Merlin 384.18 on your ax56u:
Is Astrill a VPN provider? If it runs on your main router, your entire network will be "VPNed".
byyuan
Yea, it is a vpn provider, that developed a merlin compatible applet.
I tried AIMesh. With a Merlin AX56U V1, and TUF AX3000. Before AIMesh, AX56U was functioning for Astrill. Post forming AIMesh, Astrill stopped responding. Tried to reinstall and all the trouble shooting steps, and finally gave up.
I'm returning the TUF AX3000. (But it was a great value for the speed and WIFI coverage)
Check this out:
