AImesh blocks my minecraft LAN ?
kbc
Hi
I have a ax88 router and by wifi I can play multiplayer minecraft on a game published on one of the computers bu the ingame LAN-mode (easy)
2 computers on WLAN 5G - everything works great.
PROBLEM:
I have just added a ax92 to get better coverage and the 92 is connected via cable to the ax88 and its setup as AImesh-node. Connection is great.
BUT I can't see the LAN-game published by the same computer after i added the ax92. Thus cannot play multiplayer game.
If i turn the ax92 off then I see the game again.
I called ASUS but that did not help
Why is the LAN game "blocked" .. and how do I resolve it?
Why does it work with just the ax88 and as soon as I connect the mesh-node it stop working?
Are you using AP-mode on 92U or router mode which causes double-NAT.
In AP-mode you could try to connect to an LAN port instead of WAN port of 92U.
