AiMesh - disable 2.4GHz on nodes?
Volfi
I would like to disable 2.4GHz Wifi on my node (AC86U). Main router (AC88U) should have it though. Can connect via SSH, and tried this:
wl -i wl0.1 down
wl -o wl0.1 radio off
nvram set wl0.1_radio=0
nvram set acs_ifnames="wl1.1"
nvram commit
service restart_wireless
However, node is not accesible after that.
wl0.1 = 2.4GHz
wl1.1 = 5GHz
Any hints how to achieve this?
Not sure why, but 2.4GHz devices connected to node do not work very well, disconnect often. Think this is AiMesh bug, but as I cannot solve this firmware bug, at least I tried to switch 2.4GHz on nodes off.
isnt wl0.1 first guest on 2.4G?
nvram set wl0_radio=0 should do it what I can remember.
Dont know what acs_ifnames="wl1.1" is good for, never used this, better leave it.
Nor do I know what the first both lines wl -i wl0.1 down and wl -o wl0.1 radio off shall do, let them as previous too.
No, wl -i wl0.1 status gives me 2.4GHz Wifi. Also wl0.1_ssid points to correct (2.4GHz) SSID.
Actually, you might be right :)
Doing this simple stuff keeps node connected, and switches off 2.4GHz on it :)
nvram commit
nvram commit
Thank you! This works for me. 2.4Ghz seems to give my devices trouble too.
However, the node refuses to reconnect after a reboot. It seems it needs 2.4GHz to initiate the connection. Does your router work fine after reboot?
@Phi Tran - have this problem as well.
I gave up on AiMesh and am running "node" in repeater mode, changing repeater's 2.4GHz SSID to other name, so that legacy devices do not connect to it.
I gave up on this AiMesh for a while too. This thread gave me hope, but the reboot problem shuts down this last hope. Oh well, back to none AiMesh again.
AC86U, used as an extender, has no problems when 2.4GHz is disabled via SSH.
