D
Deleted member 62525
Guest
My primary router is RT-AC86U with Merlin 386.4 firmware. My secondary router has stock firmware.
I do use an external DNS - local to my network and running on local NAS. In my current configuration with secondary router in Media Bridge mode all is working perfectly.
I tried to configure AirMesh today but with no success. Reset secondary router to defaults (hardware reset), rebooted, then use the primary router to search for the node. The whole process goes through all the way (100%) and at the very end shows a screen that says it is unable to setup the node and lists various reasons. Tried it few times and still the same.
I am puzzled at this point since the technology is mature already and I did not expect this. Any ideas would be appreciated.
I also tried reverse - meaning resetting the node, login and configure the node first to be airmesh node. Then, connecting to main router and trying to setup the node.
Still I get the samae error screen.
