Aimesh Node Firmware Upgrade
ariesjunk
My Aimesh routers cannot connect to ASUS server to check for the firmware update. I can manually upgrade the main router. However, I cannot do the same for the nodes as they do not show up on the firmware upgrade page. How can I upgrade the node firmware?
That's unusual, if the nodes are installed and working.
You could upload the main router to see if the situation improves. Otherwise, remove the nodes, upload and reset them manually, and add them back to the AiMesh. I'd also first reset the main router and configure from scratch, in case that is the issue.
OE
I'm having this issue too. Main node is merlin, two AI mesh nodes are stock Asus firmware. Simply cannot connect to Asus to check for updates anymore.
Current Asuswrt-Merlin release thread is still open:
