AImesh node with no client
crileo
Hi, I have an AImesh system with 2 RT-AC68U connected with cable, the first in my house the second in garage/garden. I have about 50 wifi devices connected and it seems to work all correct but, even if some devices are nearest garage, seems to be connected to main router as you can see in attached image....why??
I had the same issue but changing this setting forces clients to roam. Did the trick for me! :)
Located under Wireless->Professional settings for each band.
Also look under System Log->Wireless log to find the best RSSI value for you when clients should roam.
