AiMesh Router Node Maximum
jaboda
Sorry if this has been posted before but I haven't seen it mentioned anywhere.
As you may know there's a hard limit of 9 nodes in an Asus AiMesh network. Adding any more gives the error "The limit on the number of AiMesh nodes is 9. Currently your system has reached the maximum".
Today I tried to add a new AiMesh Node and it said I'd hit the maximum when I hadn't. I assumed there's a counter and it had become incorrect due to earlier topology changes I'd made.
It seems that not only is there a counter but it can be changed via SSH/Telnet. I didn't need to currently do that as I was reinstalling an existing node but I will try this in the future when we need to add more.
The config value is "cfg_recount" and it should be set on the AiMesh master to the number of Nodes installed. It's set to zero on the nodes.
To view the current value run "nvram show | grep 'cfg_recount' "
To change it simply run "nvram set cfg_recount=[number of nodes] | nvram commit".
Not only that but there seems to be a maximum as well, which is stored in "cfg_re_maxnum". Unlike the count this is stored on all Nodes as well, but not sure if it's needed.
To view the current value (which defaults to 9) run "nvram show | grep 'cfg_re_maxnum' "
To change it run "nvram set cfg_re_maxnum=[number of nodes] | nvram commit".
Has anyone else got any experience of changing these two values? How many nodes can an AiMesh run with, assuming mostly ethernet backhaul?
I am looking forward to testing this and will report back.
I did some more testing with this.
These settings are reset on reboot. The settings cfg_relist and cfg_relist_x hold the Node list which cfg_recount calculates on reboot.
Unfortunately when I tried to change these settings it cleared them as they contain < characters. So be careful!
In the end I recreated the Mesh which fixed the issue
im having the same issues from the multiple testing, removal, a router crash after firmware update fail etc etc.
>>>/tmp/home/root# nvram show | grep 'cfg_recount'
cfg_recount=9
size: 75005 bytes (56067 left)
>>>:/tmp/home/root#
Do i clear it with
Will this remove and of the existing nodes?
I had orphaned nodes that wouldn't show up in the GUI and prevented me from adding new nodes as the outer thought I had reached the 9-node limit.
This thread helped me fix the problem. Here's what I did:
  1. Use Merlin FW to ensure SCP is working (Asus firmware doesn't have it).
  2. Use an SSH client like Bitvise to logon
  3. Use WinSCP to pull up the file explorer
  4. Check the current node count
    • nvram get cfg_recount
  5. Write the cfg_relist to a file.
    • nvram get cfg_relist > cfg_relist.txt
  6. Use WinSCP to edit out the bogus/orphaned entries from the file and save
    • EDIT cfg_relist.txt with WinSCP (Notepad++) then SAVE
  7. Write the data back to NVRAM. Doing it this away dodges the "<" character issue mentioned above.
    • nvram set cfg_relist "`cat cfg_relist.txt`"
  8. Reboot and Check the count! It works!
I forgot to NVRAM COMMIT when I did the above, but it seemed to work just fine and retained everything post-boot. YMMV.
@skavan There is a typo in your nvram set command. It should be:
nvram set cfg_relist="`cat cfg_relist.txt`"
or
nvram set cfg_relist="$(cat cfg_relist.txt)"
The use of nvram commit in the previous posts is also bad practice. nvram commit should be a separate command (or use ;) and not the target of a pipe.
This was helpful but the part on editing need more information please. i thot to just leave it blank and start from scratch.
reset all my nodes, adding them successfully but they do not show up on the GUI.
Restore a backup of the list and it works for some nodes but not the "newly" added ones, some nodes that were old are visible but i cant add any nodes.
I was able to update the mesh node count on my Asus GT-AX11000. In my case, I reached the max number of nodes because I used a firmware backup from one gt-ax11000 router to a new one. The nodes that were associated with the first router, of course, never showed up in my node list in the second router. Not that this is anything special, all mesh nodes drop from the node list after being disconnected for some amount of time.
It is possible to do this entirely within the linux shell using Bitvise xterm and SSH. I'm running the stock Asus firmware, but I don't see why it wouldn't also work with Merlin.
Here's how I did it:
1. Use Bitvise to connect to connect via SSH and open a new terminal console window. You will be in the /tmp/home/root directory by default.
2. Optional- Run the command: nvram get cfg_recount
This should return the number 9 on the next line which means that the AIMesh node count is at maximum
3. Run the command: nvram get cfg_relist > cfg_relist.txt
4.
Optional- Check that the file was created by typing: ls
(lower case LS) This should show that the file cfg_relist.txt was created.
5. Use the built-in vi editor to open the file you just created in step 3 above by running the command: vi cfg_relist.txt
Opening the file for editing will give a file similar to this:
<60:45:CB:CC:C2:AA>60:45:CB:CC:C2:AA>60:45:CB:CC:C2:AA>1660125805<4C:ED:FB:36:FD:BB>52:ED:FB:36:FD:BB>52:ED:FB:36:FD:BB>1660125692<10:7B:44:A0:99:CC>16:7B:44:A0:99:CC>16:7B:44:A0:99:CC>1703070093<10:7B:44:A0:7B:AD>16:7B:44:A0:7B:AD>16:7B:44:A0:7B:AD>1703070092<4C:ED:FB:36:FD:EE>52:ED:FB:36:FD:EE>52:ED:FB:36:FD:EE>1703070100<10:7B:44:CE:C7:FF>16:7B:44:CE:C7:FF>16:7B:44:CE:C7:FF>1691456972<10:7B:44:CE:A7:11>16:7B:44:CE:A7:11>16:7B:44:CE:A7:11>1703328953<10:7B:44:A0:8B:22>16:7B:44:A0:8B:22>16:7B:44:A0:8B:22>1703070089<4C:ED:FB:36:FD:33>52:ED:FB:36:FD:33>52:ED:FB:36:FD:33>1701552086
Each record starts with the "<" character and is delimited with a ">" character between data fields.
The first hex number after the "<" represents the mac address that the main router associates with the mesh node. For example "<60:45:CB:CC:C2:AA".
You can view the mac address for each node in the "AIMesh" section of the main router admin page using computer browser (not mobile app) to connect. Click on a node in the tree figure and look in the upper right for the mac address immediately beneath the model name of the mesh node device. It's in white font, so it's easy to miss.
Each record ends with a ten-digit number corresponding to the date that the node was installed or last updated. For example ">1660125805". This is represented in seconds since Unix Epoch, i.e., 1/1/1970
6. Match the first hex digits of each of the nine records in the cfg_relist.txt file to an active AIMesh node in the admin page of the main router. Those that don't match in the cfg_relist.txt file are the orphaned mesh nodes to be removed.
7. Using vi, simply delete the orphaned records, starting with the "<" character and ending with the ten-digit date. For example, remove the first record from the example above by deleting: <60:45:CB:CC:C2:AA>60:45:CB:CC:C2:AA>60:45:CB:CC:C2:AA>1660125805
8. When finished deleting orphaned records, run the following command in vi- :wq
(that is "colon" followed by wq and then press "enter"). This will save the file and exit the vi editor.
9. Run the command: nvram set cfg_relist="`cat cfg_relist.txt`"
10.
Go to the admin page for the main router and reboot the system. The router will go through the "Applying Changes" count to 100%.
You should now have permanently removed the orphaned mesh nodes. You can run step 2 again and it should reflect the new number of nodes, equaling 9 minus the number of records you deleted.
This should be a fairly low-risk change. If you accidentally remove an active node, you should be able to reset the node and simply add it to your AIMesh again.
4.
10.
so in short, there is no way to run more than nine nodes at the same time?
You don't want to run this many routers on the same channels and AiMesh was never designed to scale this much. If you really need >9 APs better look for business series equipment. Omada and UniFi are good price/performance systems for home use.
Try using backslashes, in front of the less-than & greater-than symbols, to escape the values on the command-line:
# nvram set cfg_relist=\<60:45:CB:CC:C2:AA\>60:45:CB:CC:C2:AA\>60:45:CB:CC:C2:AA\>1660125805
# nvram commit
One can run >9 APs, no need to be AiMesh nodes. And it will allow per AP settings. AiMesh wired and on 386/388 firmware has short list of advantages and long list of disadvantages. Things get better in 102 firmware for newer devices and after 37xxx.
@RMerlin, is there a reason there is a hard limit at 9 nodes, is it because of the character limit? can you think of a way around it?
Ask Asus, not me. But quite frankly if you need that many nodes, you have the completely wrong type of product.
Sorry, I just figured you had some kind of solution. Apologies for the mistake. I will just run them as Access Points. I have a pretty large property, part of which hosts internet for an AirBNB that that has 3 bedrooms. I have a single hardwired line to the backhouse. It does great for supplying extra connections, but I was trying to manage it all under one screen like AIMESH offers. I guess simplicity is that- simplicity. Thanks anyways.
With this simplicity your Airbnb guests have access to your entire network plus other eventual complications related to Internet activities on your ISP account. Your choice, but think about proper equipment for network segmentation and some legal backup.
If you need to run more nodes than is supported (9 AiMesh nodes) by Asus consumer grade equipment, you really should consider looking at a business class product; one that can support many nodes, rather than consumer class equipment. One that you can setup VLAN's to isolate the AirBnB from your personal main LAN clients. One that is designed for business use rather than consumer use.
