AIProtection Asus apple notifications
helio58
Anyone having problem when AIProtection enable? not receiving notifications in apple devices?
I have a couple security cameras that send alerts to my phone.
When I enable AIProtection network , I don't get the notifications.
Just to see if its just me.
I have a Samsung camera and if it detects motion during specific time frames it sends me a message. The AC1900P it is connected to has AIProtection enabled. It isn't causing me any problems however I have it connected using a VPN connection/client on my router.
Which specific feature of AiProtection did you enable?
I m using a Amaryllo atom camera. it detects motion but is not sending the message.
It worked very well until i enable aiprotection.
Try disabling the Infected Device Protection and Blocking. It's possible that the camera generates traffic that is similar to that of a compromised device, causing it to get blocked by AiProtection.
It did not work.
I think I find the reason.
I must have accidentally enable DNS-based filtering.
When i disable it works
