AiProtection parental control doesn't seem to work
Col8eral
I thought I'd give th AiProtection Parental control a go, but it doesnt seem to work for me.
So i went to AiProtection>parental controls>enable web app filtering
i then selected a device and blocked everything and applied the changes.
However when testing the blocked device I can still visit adult websites, use whatsapp messenger and stream content.
Has anyone had any success with this feature and can share how they got it to work.
many thanks
many thanks
Works for me.
In Parental Controls select the Client Name from the list. When you click on it you will only see the clients MAC address. Check what you would like to block in the Content Category then click the + in a circle under Add/Delete. Click Apply.
Did you turn off the cellular data on your phone? Blocking the WiFi can cause the phone to switch to cellular.
Sent from my P01M using Tapatalk
