thelonelycoder
Part of the Furniture
Welcome, this is amtm 6.0.1, the Asuswrt-Merlin Terminal Menu
amtm is a front end that manages popular scripts for wireless routers running Asuswrt-Merlin firmware.
Starting with Asuswrt-Merlin firmware 384.15, amtm is included in the firmware.
What's new in amtm 6.0.1
Instead, LED control mirrors the Aura RGB settings made in the WebUI on ROG routers supporting this feature.
The current Aura theme is shown in lc, along with the Dark Mode setting (if supported).
How to update amtm
In the amtm menu, enter u to update to this latest version.
The firmware built-in and the legacy amtm version receive updates at the same time.
The full version history can be found on diversion.ch
amtm start command
On firmware older than 384.15, you may have to enter the full path to amtm.
Note that the command below does not work for the firmware built in amtm.
Install command for Asuswrt-Merlin firmware older than 384.15
Copy and paste the complete command below into your favorite SSH terminal, then press Enter.
Routers with Asuswrt-Merlin firmware 384.15 and newer require no installation, amtm is included in the firmware. The firmware built in amtm adds FW next to the version.
amtm is hosted on the Diversion website: https://diversion.ch/amtm.html
- Reworked LED control lc to work with wifi7, wifi6 and older firmware.
How to update amtm
amtm start command
amtm
/jffs/scripts/amtm
curl -Os https://diversion.ch/amtm/amtm && sh amtm
