visortgw
That makes sense...In other words, the Aura RGB coupling in lc is useless and can be removed as long as my logic in lc reinstates the correct setting as set in the WebUI. Right?
Well done! Everything's good right now. Thank youamtm 6.0.1 is now available
This removes the ineffective Aura RGB coupling feature in lc.
- Reworked LED control lc to work with wifi7, wifi6 and older firmware.
Instead, LED control mirrors the Aura RGB settings made in the WebUI on ROG routers supporting this feature.
The current Aura theme is shown in lc, along with the Dark Mode setting (if supported).
This might?@thelonelycoder: I reinstalled Merlin 3006.102.4 on my GT-AXE16000 AiMesh node. I subsequently installed amtm, entware, and LED control (lc). I discovered a small anomaly with the primary LED behavior. The GT-AXE16000 has four (4) LED indicators for the WiFi bands (i.e., 6 GHz, 5 GHz-1, 5 GHz-2, and 2.4 GHz). When I manually disable the LEDs via lc, the second WiFi LED from the left (one of the two 5 GHz LEDs) remains lit while all of the remaining LEDs and Aura RGB go dark.
Any thoughts on this? Any nvram dumps that might help?
Did you do the full L&LD dance? /s@thelonelycoder: I reinstalled Merlin 3006.102.4 on my GT-AXE16000 AiMesh node. I subsequently installed amtm, entware, and LED control (lc). I discovered a small anomaly with the primary LED behavior. The GT-AXE16000 has four (4) LED indicators for the WiFi bands (i.e., 6 GHz, 5 GHz-1, 5 GHz-2, and 2.4 GHz). When I manually disable the LEDs via lc, the second WiFi LED from the left (one of the two 5 GHz LEDs) remains lit while all of the remaining LEDs and Aura RGB go dark.
A remnant of the removed Aura RGB coupling that it set when enabled.I just noticed the new text: Aura Night Mode set in WebUI: On
What is Aura night mode on webui? I can't find that option in my gt-ax6000 webui, but for some reason amtm says it's on![]()
nvram set ledg_night_mode=
nvram commit
nvram set ledg_night_mode=0
nvram commit
Seriously now, this is the GT-BE98, all leds off:@thelonelycoder: I reinstalled Merlin 3006.102.4 on my GT-AXE16000 AiMesh node. I subsequently installed amtm, entware, and LED control (lc). I discovered a small anomaly with the primary LED behavior. The GT-AXE16000 has four (4) LED indicators for the WiFi bands (i.e., 6 GHz, 5 GHz-1, 5 GHz-2, and 2.4 GHz). When I manually disable the LEDs via lc, the second WiFi LED from the left (one of the two 5 GHz LEDs) remains lit while all of the remaining LEDs and Aura RGB go dark.
paperweight@GT-BE98-A804:/tmp/home/root# nvram show | sort | grep '^led_\|ledg_\|AllLED'
size: 173277 bytes (88867 left)
AllLED=0
AllLED_brightness=255
led_10g_white_gpio=4143
led_2g_gpio=255
led_5g_gpio=255
led_afc_gpio=4144
led_all_gpio=255
led_ctrl_cap=4
led_disable=1
led_extphy_gpio=255
led_group1_blue_gpio=3
led_group1_green_gpio=4
led_group1_red_gpio=2
led_group2_blue_gpio=7
led_group2_green_gpio=8
led_group2_red_gpio=5
led_group3_blue_gpio=15
led_group3_green_gpio=16
led_group3_red_gpio=14
led_lan1_gpio=255
led_lan2_gpio=255
led_lan3_gpio=255
led_lan4_gpio=255
led_lan_gpio=4097
led_logo_gpio=255
led_pwr_gpio=4146
led_turbo_gpio=255
led_usb3_gpio=255
led_usb_gpio=255
led_val=1
led_wan_gpio=4139
led_wan_normal_gpio=4113
led_wps_gpio=255
ledg_led_enable=1
ledg_new_default_rgb=
ledg_new_default_scheme=5
ledg_night_mode=0
ledg_night_rgb1=10,0,0,12,0,3,10,0,12
ledg_night_rgb2=1,0,0,1,0,0,1,0,0
ledg_night_rgb3=50,0,0,58,0,32,50,0,64
ledg_night_rgb7=50,0,0,58,0,32,50,0,64
ledg_qis_finish=1
ledg_rgb1=100,0,0,120,0,30,100,0,128
ledg_rgb2=0,22,128,0,22,128,0,22,128
ledg_rgb3=100,0,0,120,0,40,100,0,128
ledg_rgb6=100,0,0,120,0,30,100,0,128
ledg_rgb7=100,0,0,120,0,40,100,0,128
ledg_scheme=0
ledg_scheme_old=5
ledg_sdn=0<0<0
size: 173345 bytes (88799 left)
AllLED=1
led_2g_gpio=255
led_5g_gpio=255
led_afc_gpio=4144
led_all_gpio=255
led_ctrl_cap=4
led_disable=0
led_extphy_gpio=255
led_lan1_gpio=255
led_lan2_gpio=255
led_lan3_gpio=255
led_lan4_gpio=255
led_lan_gpio=4097
led_logo_gpio=255
led_pwr_gpio=4146
led_turbo_gpio=255
led_usb3_gpio=255
led_usb_gpio=255
led_val=1
led_wan_gpio=4139
led_wps_gpio=255
ledg_led_enable=1
ledg_night_mode=0
ledg_qis_finish=1
ledg_scheme=5
ledg_scheme_old=5
ledg_sdn=0<0<0
That seems consistent with mine on the GT-AXE16000.Seriously now, this is the GT-BE98, all leds off:
Code:paperweight@GT-BE98-A804:/tmp/home/root# nvram show | sort | grep '^led_\|ledg_\|AllLED' size: 173277 bytes (88867 left) AllLED=0 AllLED_brightness=255 led_10g_white_gpio=4143 led_2g_gpio=255 led_5g_gpio=255 led_afc_gpio=4144 led_all_gpio=255 led_ctrl_cap=4 led_disable=1 led_extphy_gpio=255 led_group1_blue_gpio=3 led_group1_green_gpio=4 led_group1_red_gpio=2 led_group2_blue_gpio=7 led_group2_green_gpio=8 led_group2_red_gpio=5 led_group3_blue_gpio=15 led_group3_green_gpio=16 led_group3_red_gpio=14 led_lan1_gpio=255 led_lan2_gpio=255 led_lan3_gpio=255 led_lan4_gpio=255 led_lan_gpio=4097 led_logo_gpio=255 led_pwr_gpio=4146 led_turbo_gpio=255 led_usb3_gpio=255 led_usb_gpio=255 led_val=1 led_wan_gpio=4139 led_wan_normal_gpio=4113 led_wps_gpio=255 ledg_led_enable=1 ledg_new_default_rgb= ledg_new_default_scheme=5 ledg_night_mode=0 ledg_night_rgb1=10,0,0,12,0,3,10,0,12 ledg_night_rgb2=1,0,0,1,0,0,1,0,0 ledg_night_rgb3=50,0,0,58,0,32,50,0,64 ledg_night_rgb7=50,0,0,58,0,32,50,0,64 ledg_qis_finish=1 ledg_rgb1=100,0,0,120,0,30,100,0,128 ledg_rgb2=0,22,128,0,22,128,0,22,128 ledg_rgb3=100,0,0,120,0,40,100,0,128 ledg_rgb6=100,0,0,120,0,30,100,0,128 ledg_rgb7=100,0,0,120,0,40,100,0,128 ledg_scheme=0 ledg_scheme_old=5 ledg_sdn=0<0<0
While this is with leds on:
Only differences with off an on are AllLED, led_disable and ledg_scheme.Code:paperweight@GT-BE98-A804:/tmp/home/root# nvram show | sort | grep '^led_\|ledg_\|AllLED' size: 173345 bytes (88799 left) AllLED=1 AllLED_brightness=255 led_10g_white_gpio=4143 led_2g_gpio=255 led_5g_gpio=255 led_afc_gpio=4144 led_all_gpio=255 led_ctrl_cap=4 led_disable=0 led_extphy_gpio=255 led_group1_blue_gpio=3 led_group1_green_gpio=4 led_group1_red_gpio=2 led_group2_blue_gpio=7 led_group2_green_gpio=8 led_group2_red_gpio=5 led_group3_blue_gpio=15 led_group3_green_gpio=16 led_group3_red_gpio=14 led_lan1_gpio=255 led_lan2_gpio=255 led_lan3_gpio=255 led_lan4_gpio=255 led_lan_gpio=4097 led_logo_gpio=255 led_pwr_gpio=4146 led_turbo_gpio=255 led_usb3_gpio=255 led_usb_gpio=255 led_val=1 led_wan_gpio=4139 led_wan_normal_gpio=4113 led_wps_gpio=255 ledg_led_enable=1 ledg_new_default_rgb= ledg_new_default_scheme=5 ledg_night_mode=0 ledg_night_rgb1=10,0,0,12,0,3,10,0,12 ledg_night_rgb2=1,0,0,1,0,0,1,0,0 ledg_night_rgb3=50,0,0,58,0,32,50,0,64 ledg_night_rgb7=50,0,0,58,0,32,50,0,64 ledg_qis_finish=1 ledg_rgb1=100,0,0,120,0,30,100,0,128 ledg_rgb2=0,22,128,0,22,128,0,22,128 ledg_rgb3=100,0,0,120,0,40,100,0,128 ledg_rgb6=100,0,0,120,0,30,100,0,128 ledg_rgb7=100,0,0,120,0,40,100,0,128 ledg_scheme=5 ledg_scheme_old=5 ledg_sdn=0<0<0
Never be cheap on essentials. As you very well know.That seems consistent with mine on the GT-AXE16000.
But someone must've done some full dance overnight.My entware installation on the device didn't seem to be active this morning when I tried to configure lc (i.e., dynamic time configuration grayed out). Possibly flaky USB flash drive? I replaced USB flash drive, and reconfigured lc — it works as expected now (no orphan 5G WiFi LED remaining lit when LEDs manually disabled). Doesn't really make sense, but I have no other explanation.
I'll see what happens tonight at sunset (20:35 EDT).
I use true SSDs on primary router, but flash sticks for the AiMesh nodes.Never be cheap on essentials. As you very well know.
Makes sense as the required Entware binaries were unavailable when lc sets the days cron jobs.
I‘m sure I tested this scenario and have built in exit routes for that while the script runs.
Always something new![]()
This would be the non-destructive way:
So... It doesn't appear to be a failed USB flash drive. For whatever reason, entware is "disappearing" on three (3) different AiMesh nodes:Never be cheap on essentials. As you very well know.
/jffs/scripts
on one of the three nodes:TheS1R@GT-AXE16000-B4F0:/tmp/home/root# cd /jffs/scripts/
TheS1R@GT-AXE16000-B4F0:/jffs/scripts# ls -al
drwxr-xr-x 2 TheS1R root 304 Jun 1 13:52 .
drwxr-xr-x 13 TheS1R root 2240 Dec 31 2023 ..
-rwxr-xr-x 1 TheS1R root 129 Jun 1 13:52 post-mount
-rwxr-xr-x 1 TheS1R root 60 Jun 1 07:14 services-stop
TheS1R@GT-AXE16000-B4F0:/jffs/scripts# cat post-mount
#!/bin/sh
. /jffs/addons/amtm/mount-entware.mod # Added by amtm
/bin/sh /jffs/addons/amtm/led_control.mod -set # Added by amtm
TheS1R@GT-AXE16000-B4F0:/jffs/scripts# cat services-stop
#!/bin/sh
/opt/etc/init.d/rc.unslung stop # Added by amtm
/tmp
does not exist. I manually created it using the following command, office
being my USB label:ln -s /tmp/mnt/office/entware /tmp/opt
I installed some AMTM-OSR scripts, and while I forgot exactly what script that triggered it, I also got similar errors (many of them). It eventually stopped. But what I'm sure of is that in my case it was a script I installed (not upgrading it). So, it's not necessarily old vs new database triggered, but database creation.Was this expected to happen after the script update?
and strange jump by +0.0.2 versions....(ignore MerlinAU - its on development-debugging)
I have entware on a couple of mesh nodes. Was the symbolic link also missing after you reinstalled entware (after selecting ep) or only on your original installs (after the amtm 6.01 update)?UPDATE: It appears that the symbolic link for entware in/tmp
does not exist. I manually created it using the following command,office
being my USB label:
Going back into amtm, entware is visible again:
Yes, it was also post-v6.0.1.I have entware on a couple of mesh nodes. Was the symbolic link also missing after you reinstalled entware (after selecting ep) or only on your original installs (after the amtm 6.01 update)?
Welcome To SNBForums
