amtm amtm 6.7 - the Asuswrt-Merlin Terminal Menu, April 11, 2026
Entware is *not* a requirement for YazFi or scMerlin installation. If Entware is found installed, both add-ons do detect it and can take advantage of it, but it's definitely not required for their functionality.
That's a good distinction, to know some add-ons do. I'll change the wording for those 2 add-ons then! Thanks Martinski!
I have a feeling it‘s time I re-activate the coder part of my brain. It‘s been months 😎
I've been wondering where you disappeared too, since your wandering thread. 😂
Jump in the deep end! Easiest way to get back into it. (So I've been told)
We now mark these as optional, but recommended to clarify the distinction in the documentation.
Again, thanks for the important distinction!
Or:
You're the man! 👊 👍 💪
But, as I'm a details-oriented person, I'd rather see the prerequisites section in the readme, just like how it is in scribe's readme, numbered/bulleted items list much better than a single paragraph. In short:
@Tarek Yag
I've also changed the formatting and standardized them all satisfy your desire for cleanliness in the documentation ;)
Examples seen above.
Hahaha, I've been wondering the same since @thelonelycoder disappeared! 😅
This is fine art! Thank you for your effort and collaboration!
BTW, I do really like the phrase "optional but recommended" you used in the documentation. 👊
Problem with my ADDONS and amtm 6.1.5. Should I create a new thread ?
Today, on my old ASUS RT-AC3200/ FW-384.13_10/armv7l/Kernel-2.6.36.4
I notice that the ADDONS tab was missing on my WebUI page,
so I connect with ssh on my router and type the AMTM command which gives
messages likes
ntpMerlin modified to use AMTM-OSR repository
Update now using the ntpMerlin function.
amtm 6.1.5 by thelonelycoder
RT-AC3200 (armv7l) Kernel-2.6.36.4
FW-384.13_10 @ 192.168.1.1
Operation Mode: Wireless router
Thu Dec 4 21:18:02 EST 2025
amtm - the Asuswrt-Merlin Terminal Menu
/mnt/Share_disk Size 56.4G Used 3.1G (6%)
rt open RTRMON -> 2.2.3
j2 open ntpMerlin -> 3.4.12
j3 open scMerlin -> 2.5.45
spdMerlin modified to use AMTM-OSR repository
Update now using the spdMerlin function.
j4 open spdMerlin -> 4.4.16
ep manage Entware packages
em open Email settings
sc manage Scripts update notification
dc manage Disk check script
fd run Format disk fdl show log
rs manage Reboot scheduler
sh manage Shell history
rd manage Router date keeper
sw manage Swap file /mnt/Share_disk 2.0G
cj show all cron jobs
i show available scripts
amtm options
u update rr reboot
e exit t theme r reset a about
_____________________________________________
Enter amtm option
I then type the 'U' command which said:
Third-party script update(s) available! Use
the scripts own update function to update.
then I use the 'j2' command to enter ntpMerlin function
but this does not open the ntpMerlin function, it just repeat the content of the previous spoiler
idem for the scMerlin and spdMerlin functions
I cannot enter into these functions
Also, I notice that the 'cru l' command shows only 2 lines
10 5 * * Sun /bin/sh /jffs/addons/amtm/sc_update.mod -run #amtm_ScriptsUpdateNotification#
*/2 * * * * /etc/openvpn/server1/vpns-watchdog1.sh #CheckVPNServer1#
It missed many of my daily cronjob
I do not know where to begin, I am confused
Can someone gives me some hints. It will be appreciated.
Thanks in advance
messages likes
amtm options
u update rr reboot
Enter amtm option
Thanks in advance
The device and firmware are no longer supported. i'm not sure that you'll find someone to spend time on this one. 🙄
messages likes
amtm options
u update rr reboot
Enter amtm option
Thanks in advance
You could try installing the add-ons by downloading each from its respective AMTM-OSR GitHub repo.
scMerlin:
Bash:
curl  -LS --retry 3 --retry-delay 5 --retry-connrefused \
https://raw.githubusercontent.com/AMTM-OSR/scMerlin/master/scmerlin.sh \
-o /jffs/scripts/scmerlin && chmod a+x /jffs/scripts/scmerlin && \
/jffs/scripts/scmerlin install
ntpMerlin:
Bash:
https://raw.githubusercontent.com/AMTM-OSR/ntpMerlin/refs/heads/master/ntpmerlin.sh \
-o /jffs/scripts/ntpmerlin && chmod a+x /jffs/scripts/ntpmerlin && \
/jffs/scripts/ntpmerlin install
spdMerlin:
Bash:
https://raw.githubusercontent.com/AMTM-OSR/spdMerlin/master/spdmerlin.sh \
-o /jffs/scripts/spdmerlin && chmod a+x /jffs/scripts/spdmerlin && \
/jffs/scripts/spdmerlin install
However, as @visortgw already mentioned, the F/W 384.13_10 version is very old, and some (most?) of the add-ons may no longer work smoothly (or at all in some cases) on your particular router; and if that's the case, I doubt the developers/maintainers would spend time debugging, troubleshooting, and fixing whatever doesn't work in such an old platform, unless it's something very obvious and easy/quick to address, or if it also affects more recent F/W versions.
My 2 cents.
@itibi, I'm using scMerlin, and spdMerlin on a very old similar router (RT-AC68U) without any issues at all. I'll try to provide some help as far as I could. However, you'll need to consider updating your firmware to the latest (and maybe last) release available now (Asuswrt-Merlin 386.14_2) after solving your router issues, and eventually plan a router upgrade.
First of all, I believe there should be an error message shown after you try to run your already installed scripts (using j3, j4, etc.) from the AMTM main menu. It appears at the very bottom after the main menu reloads. Please provide the error message as it might indicate the direct/whole issue(s) you have.
You might have lost -for some reason- some files in your /jffs/scripts directory, this way you'll have to install the scripts again using the commands Martinski provided above. However, you might lose your previous scripts data when executing another install, so you better try to do a manual update or force update before going that direction.
If you prefer to try first an update or force-update, let me know what error message(s) you're getting in your AMTM main menu after trying to run each script, in order for me to provide more relevant help to you. And to cut down time and effort, please provide the output of the following command which will give me a quick insight of what issue-relevant script files you still have in your scripts directory.
# find /jffs/scripts -name '*merlin'
Many thanks for your responses.
After uninstalling and reinstalling my addons, the problem was resolved. Thanks.
Also, all files on my scripts directory were empty!! so a restore from backup resolves it.
Base on a quick overview, it seems that everything return to normal.
Many thanks again for your great help. You are my champions ;-)
Also, I check on https://www.asuswrt-merlin.net/
and it seems that the latest firmware is 384.13_10 which is already installed.
So, I will ask Santa for a newer Asus router.
I will read the article https://www.snbforums.com/threads/latest-oct-2024-best-recommended-router-for-merlin.92691/
and see if there is a newer article.
I would like to find a router that will be supported ideally for 5 more years
Thanks and have a nice day
Hi! Networkers,
After some readings, I am hesitating between 3 models : RT-BE86U, RT-BE88U and newest RT-BE92U)
They are all supported by Asuswrt-Merlin and they are all recent so I expect that EOL is far away.
My heart told me to choose RT-BE92U
Any comments ?
Hi! Networkers,
Any comments ?
FYI this topic is for discussing the Addon AMTM script/program not about asking which router one should buy. If your question isn't related to AMTM, you may want to find some other subforum here to start a new topic or find a past existing topic that discusses "which router to buy" and is relevant to the routers you are reviewing.
Hi! Networkers,
Any comments ?
There is another forum dedicated to BE routers you may want to check out.
https://www.snbforums.com/forums/asus-be-routers-adapters-wi-fi-7.61/
FYI: I picked up a RT-BE88U a couple of months back that I have been very happy with.
amtm 6.2 is now available
  • Fixes correct detection of Scribe when installing j6 uiScribe. Thanks to @Martinski for the pull request.
  • Moved AMTM Orphaned Script Revival (AMTM-OSR) repo Asterisk (*) denotation in i install screen to end of line.
  • Added Entware requirement or recommendation for each script in i install screen, see screenshot.
Apparently my Entware install is quite out of date and I didn't realize it until yesterday.
Going through AMTM (which is completely up to date) I get this:
Even if I try to change server, it defaults back to / /
It goes back to
Choosing entware repair reinstall doesn't change anything.
Choose entware repair reinstall *all* completely borks my entire installation because it deletes stuff and then tries to update files and those files can't be found and trying to fix it required a complete removal and reboot of amtm till i could reinstall backupmon and get my previous configuration. Which is what I spent most of my morning doing. Luckily my backup worked, but then it resolves back to this exact same problem.
Things I've tried: remove adguard home, change dns settings on router and everything as though AGH didn't exist - Didn't fix it. Trying to run opkg update does nothing, though opkg list does show a bunch of outdated software.
I'm pretty sure it has to do with wget based on this thread but I'm not having any luck there either.
Not sure if that makes this an amtm problem or not at that point. I feel like i'm pretty fracking close to solving it but i'm missing the exact commands.
It goes back to
The first line of /opt/etc/opkg.conf is missing on your router.
Run cat /opt/etc/opkg.conf and you should see this, with a blank line at the top:
dest root /
dest ram /opt/tmp
lists_dir ext /opt/var/opkg-lists
option tmp_dir /opt/tmp
arch all 100
arch aarch64-3.10 160
If so, run this command that is correct for YOUR router:
sed -i '1s#^#src\/gz entware https://bin.entware.net/aarch64-k3.10#' /opt/etc/opkg.conf
And then another cat on the file should show a complete file:
src/gz entware https://bin.entware.net/aarch64-k3.10
dest root /
dest ram /opt/tmp
arch all 100
If there is no blank line, or something else is missing in that file as shown in the above code, consider using nano /opt/etc/opkg.conf to edit the file and replace everything with the above code in file /opt/etc/opkg.conf
Apparently opt/etc/opkg.conf was missing entirely. I have no idea how the hell that could have happend.
I was able to do everything else though and now its working! opkg upgrade is actually updating. Wow did it update a lot of files.
Thanks a ton!
I have created a kind of “extension” that allows WireGuard clients to be managed in a more active way, and I am wondering whether a script like this can be included in the amtm menu so that, when I start amtm, I can launch my own menu script using a dedicated key.
I could not find any documentation explaining how a personal script can be onboarded into amtm for private use.
Let me briefly describe what this extension does.
In short:
Asus-Merlin allows configuring up to five WireGuard clients in the VPN Client section. Once configured, this setup is static:
(I use this feature with a paid NordVPN subscription, so Private Key is grayed out, obviously)
What is missing, however, is:
- scheduled endpoint rotation, and
- a watchdog that monitors the WireGuard tunnel health and reacts when a tunnel becomes unusable (for any reason, like for example Endpoint being decommissioned) by recreating it.
My solution consists of two scripts:
- nordwg_rotate.sh – forces WireGuard endpoint rotation according to schedules defined via cru
- nordwg_watchdog.sh – periodically checks WireGuard tunnel health and forces a new setup when an existing tunnel is not healthy
Both scripts are triggered via cron entries:
NordVPN cron schedules:
30 00 * * * /jffs/scripts/nordwg_rotate.sh #nordwg_rotate#
*/6 * * * * /jffs/scripts/nordwg_watchdog.sh #nordwg_watchdog#
Additionally, I have a menu script (nordwg-menu.sh) that provides:
- a status overview and configuration options for how both scripts operate:
- access to logs:
2026-01-25 14:36:06 [ROTATE] Starting WireGuard endpoint rotation (full)
2026-01-25 14:36:08 [ROTATE] Candidate servers: 412
2026-01-25 14:36:08 [ROTATE] wgc1: Applying de1088.nordvpn.com load 14%
2026-01-25 14:36:08 [ROTATE] wgc1: -> Public key used: 3ZNjosvvIqfv...
2026-01-25 14:36:08 [ROTATE] wgc2: Applying de1097.nordvpn.com load 16%
2026-01-25 14:36:08 [ROTATE] wgc2: -> Public key used: 3ZNjosvvIqfv...
2026-01-25 14:36:08 [ROTATE] wgc3: Applying de1073.nordvpn.com load 16%
2026-01-25 14:36:08 [ROTATE] wgc3: -> Public key used: 3ZNjosvvIqfv...
2026-01-25 14:36:08 [ROTATE] Rotation finished
My goal is to add an entry to the amtm menu, under a defined key, so I can launch nordwg-menu.sh directly from amtm.
Is this possible, and if so, how should it be implemented?
