amtm amtm 6.7 - the Asuswrt-Merlin Terminal Menu, April 11, 2026
Amtm if run write in addon row Au is disabled
If you want to change that just open Merlin AU. Navigate to Advanced Option and disable Auto-Updates for MerlinAU Script.
Exit MerlinAU and then in AMTM run update again. It will no longer show as disabled.
But if I understand correctly it now becomes a manual update that will only be updated when you select update
in AMTM.
It could not be more clearer than that. amtmupdate IS disabled in MerlinAU. Just as I wrote in my first reply.
To clarify, it may be confusing:
Header "Scripts supporting amtmupdate" lists all scripts that SUPPORT amtmupdate as an overview. That list remains unchanged, irrespective of any of the settings set in the below listings.
Header "Scripts set as disabled in amtm for amtmupdate" lists all scripts that are manually disabled by the user (like you) in amtm itself. It does not affect the setting in the respective script. The option "Disable or enable script for amtmupdate" changes this setting IN amtm only.
Header "Scripts set as disabled in script for amtmupdate" lists all scripts where the script itself (like MerlinAU) has set amtmupdate as disabled. It can only be changed in that script.
in AMTM.
Yes this work thank you.
But in ui is disabled maybe bug support Au in this addon
in AMTM.
At the moment I recommend leaving MerlinAUs auto-update feature as is.
This may change when amtm can run the amtmupdate function automatically in a future update.
If this is a bug in MerlinAU, then move discussion over to its thread.
Definitely, I only disabled it to show a point. It was quickly re-enabled.
I do prefer the auto-update feature on MerlinAU. Can't wait to aee an AMTM auto-update but, if
that entails all addon's as well then that scares me a bit.
Rozhodně jsem to deaktivoval jen proto, abych ukázal jeden bod. Rychle to bylo znovu zapnuté.
Preferuji funkci automatických aktualizací na MerlinAU. Nemůžu se dočkat automatické aktualizace AMTM, ale pokud...
to zahrnuje i všechny doplňky, to mě trochu děsí.
Maybee mail notification in AMTM some update send email what and version and git link
Maybe that message needs to be clearer. It looks like the auto updates in MerlinAU are disabled but,
they are not. It's just AMTM auto-update of the addon is disabled.
I don't see a bug, maybe just some user confusion.
If you disabled Auto-Updates in MerlinAU, that webUI will show disabled. (As it does)
They are 2 separate features, as people have tried to explain to you already.
MerlinAU disables "amtm updates" if you have Auto-Updates enabled in the MerlinAU script itself.
If you disable auto-updates in the MerlinAU script itself, then "amtm updates" becomes available again.
Nevidím žádnou chybu, možná jen zmatek uživatele.
Pokud jste v MerlinAU zakázali automatické aktualizace, webové rozhraní se zobrazí jako zakázané. (Jak se zobrazuje)
Jsou to dvě oddělené funkce, jak se vám už lidé snažili vysvětlit.
MerlinAU zakáže „aktualizace amtm“, pokud máte v samotném skriptu MerlinAU povoleny automatické aktualizace.
Pokud v samotném skriptu MerlinAU zakážete automatické aktualizace, budou „aktualizace amtm“ opět k dispozici.
I understand now but I think description in command line and also ui after new ui in amtm not are clearly
What would you prefer to see?
Example if go to amtm and click u option some better description, now this show as all updates are disabled by MerlinAU.. And in Au in AMTM show as enabled this is mistake
I'm seeing the same. au is disabled in MerlinAU, but I still can't enable MerlinAU in amtm's au.
If I select option 2 for the log it goes back to amtm with this message
Let me know how I can help debug
I understand the wording could be better or more elaborate.
We are talking of one function in amtm.
If the script supports the function and has it enabled, then amtm can update said script if it detects a version change.
With that confusion of how and what this feature does I’m inclined to remove it :mad:
I think is good for me. Maybee description Maybee merge updates automatic to one place amtm, also updates amtm possible setting as au by amtm and remove from another addon. Windows have all updates on in place also for third party company.. "all"..
Developers can disable amtmupdate in their script, even though they support the feature. Be that as MerlinAU does when its own auto-update function is enabled or by user choice which Diversion has.
amtm cannot overwrite this, it has to be set in the supported script.
So you seem to be suggesting amtm will not update MerlinAU as it's not supposed to? More confusion lol
