I've been using a pair of Netgear WNHDE111 N bridges to connect a PC in my bedroom to the router and server in my study for about a year now. They are about 25' apart with the bedroom unit sitting the same height as the study unit, with two sheet rock walls between them.
I've been getting routine performance, no problem streaming audio or surfing the internet, and fair to good performance streaming HD TV (avg 15 Mb/sec load). If I try to stream my test Bluray (Avatar, with full HD sound intact, a steady 35 - 40 Mb/s load), they choke instantly, won't even play the credits.
I decided to move the bedroom unit to a higher location (maybe 3' higher than the study unit), but with only one wall between them.
I thought I might get slightly better performance, maybe fewer drop-outs, maybe fewer buffer over runs.
What I got amazed me. The bedroom unit was off for maybe 10 minutes while I ran cables. When I had it hooked up and running, I decided to try Avatar to see if there was any change.
It was amazing, Avatar played for 30 minutes straight with only two tiny drop-outs (single frame skips with no interruption in the sound).
I stopped Avatar, did something for a few minutes, then tried Avatar again just to make sure, and it was back to the way it had always been, wouldn't even play the first two seconds of the credits without stuttering.
Other performance is as before now.
Sorry for the long story, but does anyone have any idea of what may have happened?
If I could "fix" whatever changed, I'd have a super performing N bridge that I could actually use to stream Bluray content.
