Any changes make to router -> Cable to FIOS?
JohnD5000
I just had FIOS installed. Supposed to be a 500 DL / 500 UL speed plan. I'm getting over 500 DL, but upload is only around 375. Are there any settings on router (I'm on GT-AX6000) that I should try, I was on cable, and have not made any changes to router.
Different company but same issue right after I switched. I called their tech support and they remotely reconfigured the port on the ONT I was connected to. They bounced the port and all was good with the world. Hope this helps. Now my UL is slightly faster than DL but mostly equal.
May not apply to your case but I moved a while back and went from 10/1 DSL to 100/100 FIOS with the same provider. When the install tech finally got the FIOS working I was still at 10/1. The same speed as DSL! After some head scratching, the tech called his support and had the account re-provisioned to the 100/100 bandwidth. And voila! It worked!
No changes to my router were needed.
Residential ISP lines are shared and not guaranteed. The bandwidth is "up to". Most ISPs have bandwidth to subscribers >1:10 ratio. Your speedtest results may vary in different hours of the day.
OP stated they are on FIOS, Verison's fiber option.
