Apache on RT-N66U works but...
spl
I install apache on rt-n66u with merlin firmware
it's runing but dosen't open page by name or ip
Nmap - say 9000/tcp open cslistener
It's my Apache port
If it's open and listening i can go to [domain name in hosts] or [ip]
and i see It works from apache, but it not happens in error log i don't see any errors
admin@RT-N66U:/tmp/home/root# cat /opt/var/apache2/log/error_log
[Tue Oct 08 18:21:12 2013] [notice] Digest: generating secret for digest authentication ...
[Tue Oct 08 18:21:12 2013] [notice] Digest: done
[Tue Oct 08 18:21:14 2013] [warn] pid file /opt/var/apache2/run/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
[Tue Oct 08 18:21:14 2013] [notice] Apache/2.2.20 (Unix) mod_ssl/2.2.20 OpenSSL/0.9.7m DAV/2 configured -- resuming normal operations
admin@RT-N66U:/tmp/home/root# ps w | grep apache
1890 apache 12892 S /opt/sbin/httpd -k start
1891 apache 13188 S /opt/sbin/httpd -k start
1892 apache 13188 R /opt/sbin/httpd -k start
1893 apache 13076 S /opt/sbin/httpd -k start
1894 apache 13076 R /opt/sbin/httpd -k start
1895 apache 7692 S /opt/sbin/httpd -k start
1896 apache 7692 S /opt/sbin/httpd -k start
1897 apache 13188 S /opt/sbin/httpd -k start
1898 apache 7692 R /opt/sbin/httpd -k start
1899 apache 13188 R /opt/sbin/httpd -k start
1900 apache 7692 R /opt/sbin/httpd -k start
1901 apache 13188 R /opt/sbin/httpd -k start
1902 apache 13188 R /opt/sbin/httpd -k start
1909 apache 13188 R /opt/sbin/httpd -k start
1910 apache 13188 R /opt/sbin/httpd -k start
1911 apache 13188 R /opt/sbin/httpd -k start
1912 apache 13188 R /opt/sbin/httpd -k start
1913 apache 13076 S /opt/sbin/httpd -k start
1914 apache 7692 R /opt/sbin/httpd -k start
1915 apache 7692 R /opt/sbin/httpd -k start
1916 apache 7692 R /opt/sbin/httpd -k start
1917 apache 7692 R /opt/sbin/httpd -k start
1918 apache 7692 R /opt/sbin/httpd -k start
1919 apache 7692 R /opt/sbin/httpd -k start
1920 apache 7692 R /opt/sbin/httpd -k start
1927 apache 7692 R /opt/sbin/httpd -k start
1928 apache 7692 R /opt/sbin/httpd -k start
1938 apache 7692 R /opt/sbin/httpd -k start
1939 apache 7692 R /opt/sbin/httpd -k start
1940 apache 7692 R /opt/sbin/httpd -k start
1941 apache 7692 R /opt/sbin/httpd -k start
1942 apache 7692 R /opt/sbin/httpd -k start
1943 apache 7692 R /opt/sbin/httpd -k start
1944 apache 7692 R /opt/sbin/httpd -k start
1945 apache 7692 R /opt/sbin/httpd -k start
1946 apache 7692 R /opt/sbin/httpd -k start
1947 apache 7692 R /opt/sbin/httpd -k start
1948 apache 7692 R /opt/sbin/httpd -k start
1949 apache 7692 R /opt/sbin/httpd -k start
1950 apache 7692 R /opt/sbin/httpd -k start
1951 apache 7692 R /opt/sbin/httpd -k start
1952 apache 7692 R /opt/sbin/httpd -k start
1953 apache 7692 S /opt/sbin/httpd -k start
1954 apache 13188 R /opt/sbin/httpd -k start
1955 apache 13188 R /opt/sbin/httpd -k start
1956 apache 13188 R /opt/sbin/httpd -k start
1957 apache 13188 R /opt/sbin/httpd -k start
1958 apache 13076 R /opt/sbin/httpd -k start
1959 apache 13076 R /opt/sbin/httpd -k start
1960 apache 13076 R /opt/sbin/httpd -k start
1961 apache 13076 R /opt/sbin/httpd -k start
admin@RT-N66U:/tmp/mnt/sda1/asusware# cat S80apache.1
#!/bin/sh
if [ ! -e /etc/nsswitch.conf ]; then
    echo "hosts: files dns" >/etc/nsswitch.conf
fi
Which configs i need to check, maybe some option or i can miss something?
Found problem
http://tomatousb.ru/viewtopic.php?f=4&t=13 - in rus
Short:
Need for MIPS architecture recompile apache:
For recompile with PMP Prefork we need:
in file optware/ddwrt/make/apache.mk:
comment:
#APACHE_MPM=worker
and uncomment
APACHE_MPM=prefork
after it run in optware/ddwrt/:
make apache-ipk
and in folder optware/ddwrt/builds/ will be compiled:
apache_2.2.9-1_mipsel.ipk
apache-manual_2.2.9-1_mipsel.ipk
we need "apache_2.2.9-1_mipsel.ipk" copy to router, but delete before previous ipkg install apache_2.2.9-1_mipsel.ipk
Looking for sources of apache...
Entware or Optware?
If there is a problem with the Entware one, contact ryzhov_al about it - he'll be able to sort it out if needed.
