Apple: "Limited Compatibility" of separate network names per band?
onesus
Just upgraded from RT-AC86U to GT-BE98 Pro. As was my custom with the old router on the new one I assigned SSID names that include a band designation. On Mac mini M4 Pro, macOS System Settings for Wi-Fi shows connection to one of the two 6GHz bands. The Details button shows this warning: "Limited Compatibility / This network is configured with a separate network name for 6GHz, which may impact some experiences like AirPlay. If this is your Wi-Fi network, configure the router to use a single network name for all bands." Then there's a "Learn more..." link: Recommended settings for Wi-Fi routers and access points.
The linked page says, "Make sure that all routers on your network use the same name for every band they support. If you give your 2.4 GHz, 5 GHz, or 6 GHz bands different names, devices might not connect reliably to your network, to all routers on your network, or to all available bands of your routers. If your router is providing a Wi-Fi 6E network that isn't using the same name for all bands, Apple devices that support Wi-Fi 6E will identify the network as having limited compatibility." The page links to yet another page, Use Wi-Fi 6E networks with Apple devices that says, "If the router isn’t using the same name for all bands, your device identifies the network as having limited compatibility. It then finds the name of the corresponding 5 GHz network and asks whether you want to join it for better compatibility" And in the spirit of vagueness already established: "If you select Not Now, your device continues to use the Wi-Fi 6E network, but your overall experience with some activities over the network might not be as expected."
It's not clear to me that this warning and advice applies to my single-router network. Also, I have no idea how, if all bands have the same name, a device determines which one to connect to. Currently, based on habit formed using the RT-AC68U, I choose the band from the SSIDs shown as available with each SSID name indicating its band.
Despite my having a "Pro" router and a "Pro" Apple Silicon CPU, I'm not a pro with respect to networking.
Just go back to using the SmartConnect feature with a single SSID for all bands and let the router and clients figure out which band they want to connect to. If you want a separate SSID for something set up a guest WIFI.
Your router and Mac Book know more about modern WIFI than you do. Best to not second guess them...
OK... BBBBut I can't find a `Smart Connect` setting anywhere. It's not where the User Manual says it is, nor in either of the two Web UI places (depending on firmware version) that the ASUS FAQ describes on How to configure the Smart Connect in ASUS Router? I'm running Merlin, as I always have. Doesn't seem likely that would do away with Smart Connect, but I dunno.
Related note: I currently have the 2.4GHz and 5GHz SSID names the same as they were on the old router, with the same passwords. All the devices, including some ancient ones, automagically connected to the BD98. If I succeed in using just one SSID, will I have to individually access the UI of each of a bunch of devices to connect them?
Edit to add: Via the User Manual I found a Network Rules :: Smart Connect Rule tab but (a) it appears to assume Smart Connect is already on, and (b) the various available rule criteria are beyond my ken.
It is at the top of the Wireless-General GUI page. In the English users manual see page 77.
As I said previously, "It's not where the User Manual says it is ..." Herewith a screen shot of my Wireless::General tab.
It appears it may have been removed for either that router model, or more likely on the newer BE series routers on the 3006.102.3700 (or possibly 3.0.0.6.102_35404) or newer firmware. The following thread may have some relevant information.
A reply in that discussion (post #4) indicates that Smart Connect is always on unless one separates all of the WiFi bands with different SSIDs.
PS: Also see this post which may (or may not) be relevant since it discusses Smart Connect.
Its possible using the Asus router app might be a option.
Flash the Asus firmware and try again. The Merlin firmware may be the issue. Or you have set the SSID's on another screen.
On your setup screen there is a check box on the bottom of the page that allows a separate SSID for each band. Factory reset the router and set it up again but unchecked that box at the bottom of the page where you set the SSID. See manual page 17.
All right, thanks for your research. I'll pursue this further.
I did set them on another screen -- Network, the third screen from the top in the General settings section.
I will do that. I assume now that I will be able to turn on Smart Connect. Do you know offhand if, e.g., a Wi-Fi 4 device which was, and at this writing still is, on, say, a 2.4GHz band with SSID of `ONESUS24` will automatically connect with Smart Connect's single SSID (assuming the WPA2 password is unchanged)?
In any case, thanks for your follow-through!
SmartConnect as a setting was removed, but SmartConnect is still there.
Under Network you mention you can create a Main SSID, select 2 or more channels, for example 2.4 GHz and 5 GHz checkboxes, then type SSID and Password. (These two are then SmartConnected).
Apple unfortunately mashed up their instructions...
Create another Main SSID, this time check 6 GHz-1. Name the SAME_SSID as 2.4 and 5 GHz, use the same Password.
This should cause the warning from any Apple device to disappear. Apparently starting with 6E a form of MLO was available, and that is why it wants 5 GHz and 6 GHz to have same SSID and Password, BUT also NOT Smart Connected. (Because SmartConnect will band steer which is not quite the same).
It's up to you what you want to do with 6 GHz-2. I just name it the same and same password as well....
I leave 6 GHz-1 on AXE mode, I enable WiFi 7 on 6 GHz-2.
[...] if, e.g., a Wi-Fi 4 device which was, and at this writing still is, on, say, a 2.4GHz band with SSID of `ONESUS24` will automatically connect with Smart Connect's single SSID (assuming the WPA2 password is unchanged)? [...]
To answer my own question: no, it won't. Each device must be manually connected to the new single-SSID network.
Apple is going to throw this error/notice if the SSID's across the 3 bands are not matched...
For WiFi6e, this means WPA3 is going to be a thing, and one that has considerations for 2.4 and 5GHz - there you can do WPA2/3 mixed, with 6GHz being WPA3 (only) and use a common passphrase across all three...
You're in control of your network, but suffice it to say, Apple prefers that all the radios have a common SSID, and a common security context.
Nothing MLO oriented in WiFi 6/6e - Apple is just following the general intent on IEEE with regards to an SSID representing a logical network (e.g. a different SSID represents a different network).
Thank you for correcting me. It may be more appropriate for me to note MPTCP, but that does not involve two simultaneous WiFi bands like MLO....
