TPLink router will not use Asus firmware.Hi, is the Archer AX11000 supported? I tried to install the GT-AX11000 firmware but the admin ui rejected it and said it was the wrong file type....the Archer firmware have .bin endings...
Thanks.
Of course the Archer AX11000 rejected the Asus Merlin firmware. You are trying to use a firmware designed for Asus routers on a completely different manufacturer's product.Hi, is the Archer AX11000 supported? I tried to install the GT-AX11000 firmware but the admin ui rejected it and said it was the wrong file type....the Archer firmware have .bin endings...
Thanks.
Welcome To SNBForums
