Does Roaming Assistant Not Work Anymore ?
You realize that Apple has billions of samples across the same amount of networks and they have total control over their wifi stack across multiple platforms over the past 15 years...
They're likely right with thresholds...
To be honest they aren't lol Meaning I have my Mac deciding to stay on a node all the way on the opposite side of my house. If I manually toggle the wifi.. It connects to the right one lol.
Maybe in your house - my house is just fine... Synology just works...
Again - this might be one of those things - Asus has never been open/friendly with Apple devices - long known issues..
I understand I’m trying to see if there’s a way to fix this known issue. Other than that I love the Asus system.
What type of hardware do you have if you’re saying yours is working correctly? Also do you use Smart Connect? Do you separate the 2.4ghz SSID from the 5GHZ ?
