Assigning static WAN IP addresses on Asus RT-N66U
blizeH
I've just purchased an Asus RT-N66U router and am trying to configure my multiple IP addresses (I have a block of 8, or rather 5 usable IPs)
On my previous router I ran the following:
:ip ipadd intf=LocalNetwork addr=IP4/29 addroute=enabled
:ip ipadd intf=LocalNetwork addr=IP3/29 addroute=enabled
:ip ipadd intf=LocalNetwork addr=IP2/29 addroute=enabled
:ip ipadd intf=LocalNetwork addr=IP1/29 addroute=enabled
:ip ipadd intf=LocalNetwork addr=IP0/29 addroute=enabled
:ip ipadd intf=LocalNetwork addr=IP9/29 addroute=enabled
:nat mapadd intf=Static outside_addr IP4 weight 1 index=0
:nat mapadd intf=Static outside_addr=IP9 inside_addr=192.168.1.50 weight=120 access_list IP9
:nat mapadd intf=Static outside_addr=IP9 inside_addr=192.168.1.50 weight=120 access_list 192.168.1.50
:saveall
:nat mapadd intf=Static outside_addr=IP0 inside_addr=192.168.1.51 weight=120 access_list IP0
:nat mapadd intf=Static outside_addr=IP0 inside_addr=192.168.1.51 weight=120 access_list 192.168.1.51
:nat mapadd intf=Static outside_addr=IP1 inside_addr=192.168.1.52 weight=120 access_list IP1
:nat mapadd intf=Static outside_addr=IP1 inside_addr=192.168.1.52 weight=120 access_list 192.168.1.52
:nat mapadd intf=Static outside_addr=IP2 inside_addr=192.168.1.53 weight=120 access_list IP2
:nat mapadd intf=Static outside_addr=IP2 inside_addr=192.168.1.53 weight=120 access_list 192.168.1.53
:nat mapadd intf=Static outside_addr=IP3 inside_addr=192.168.1.54 weight=120 access_list IP3
:nat mapadd intf=Static outside_addr=IP3 inside_addr=192.168.1.54 weight=120 access_list 192.168.1.54
:service system ipdelete name=TELNET ip=149.255.104.16
:saveall
Someone helped me configure it, and honestly I don't know where to start in writing that for the new router, or if it's even required?
Has anyone used one of the Asus routers (firmware version 3.0.0.4.374_979-gbc8961e) and successfully managed to configure multiple WAN IP addresses? I was hoping there would be something in the control panel, but I can't find anything.
Thanks!
http://www.linuxquestions.org/quest...blic-ip's-to-private-ip's-326993/#post1663981
Capt_Caveman said:
Ok, so I would probably just create a bunch of aliases (virtual interfaces) for each of the public IPs so that you have general connectivity (though not necessary), then just write a DNAT rule for each mapping and forward the required ports to the LAN server. Just remember that iptables will treat each of the virtual interfaces as one interface, so eth0:1, eth0:2, and eth0:3 would all be just eth0 in your iptables rules (using aliases in the rules will cause an error). So your DNAT rules will look like:
iptables -t nat -A PREROUTING -i eth0 -d 65.66.67.150 -j DNAT --to-destination 192.168.1.2
iptables -t nat -A PREROUTING -i eth0 -d 65.66.67.151 -j DNAT --to-destination 192.168.1.3
If you want to forward each of those ports to all of the internal servers, then your forwarding rules will be:
iptables -A FORWARD -p tcp -m multiport --dports 21,23,25,53,80,110,443,3389,5561,5562 - j ACCEPT
If you only want to forward certain ports to certain LAN servers, then just specify which ports and which internal IPs. For example say you only want port 80 and 443 going to 192.168.1.2 and ftp going to 192.168.1.3. Then your rules would be:
iptables -A FORWARD -p tcp -m multiport --dports 80,443 -d 192.168.1.2 -j ACCEPT
iptables -A FORWARD -m tcp --dport 21 -d 192.168.1.3 -j ACCEPT
Aliases:
ifconfig eth0:0 WANIP0 netmask WANMASK0 up
ifconfig eth0:1 WANIP1 netmask WANMASK1 up
i'm not sure if eth0 should have it's own ip or if it should be nuked and set on eth0:0 instead. my guess is that leaving an IP on eth0 is fine.
never done this before, but i think the above will work
and of course, this will all need to be added to a start script on asuswrt-merlin, stock lacks persistent storage (jffs)
Thank you very much for the reply, so that would involve flashing the router and installing asuswrt-merlin? Would you recommend that or dd-wrt?
D Asus RT-AC86U Dual Wan and IPV6 ASUS N Routers & Adapters 8
