Asus AC56u USB port broken?
smnrock
Apologies for creating duplicate thread, but the previous one was created in wrong location... I hope this thread gets more visibility!
Suddenly USB ports in my AC56u was stopped working which was running merlin firmware. Then i tried with original asus firmware and other firmwares as well, but without any luck. Now im back to latest merlin firmware, but still the problem exists. The log says, over current in usb port.
Any help? Or its a hardware issue?
Aug  1 05:30:22 kernel: hub 1-0:1.0: USB hub found
Aug  1 05:30:22 kernel: hub 1-0:1.0: 1 port detected
Aug  1 05:30:22 kernel: [xhci-hub] usb2mode:[0]
Aug  1 05:30:22 kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Aug  1 05:30:22 kernel: ehci_hcd 0000:00:0a.1: EHCI Host Controller
Aug  1 05:30:22 kernel: ehci_hcd 0000:00:0a.1: new USB bus registered, assigned bus number 2
Aug  1 05:30:22 kernel: hub 1-0:1.0: over-current change on port 1
Aug  1 05:30:22 kernel: ehci_hcd 0000:00:0a.1: irq 111, io mem 0x18021000
Aug  1 05:30:22 kernel: ehci_hcd 0000:00:0a.1: USB 0.0 started, EHCI 1.00
Aug  1 05:30:22 kernel: hub 2-0:1.0: USB hub found
Aug  1 05:30:22 kernel: hub 2-0:1.0: 2 ports detected
Aug  1 05:30:22 kernel: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Aug  1 05:30:22 kernel: ohci_hcd 0000:00:0a.0: OHCI Host Controller
Aug  1 05:30:22 kernel: ohci_hcd 0000:00:0a.0: new USB bus registered, assigned bus number 3
Aug  1 05:30:22 kernel: ohci_hcd 0000:00:0a.0: irq 111, io mem 0x18022000
Aug  1 05:30:22 kernel: hub 3-0:1.0: USB hub found
Aug  1 05:30:22 kernel: hub 3-0:1.0: 2 ports detected
Aug  1 05:30:22 kernel: hub 2-0:1.0: over-current change on port 1
Aug  1 05:30:22 kernel: usbcore: registered new interface driver usblp
Aug  1 05:30:22 kernel: hub 2-0:1.0: over-current change on port 2
Sent from my XT1562 using Tapatalk
