Asus AC87U Advanced Wireless WebUI bug
Dmytro
Hello. I have Asus RT-AC87U with installed 384.13_10 merlin firmware
when I try to go to Wireless section in the left menu I get errors in console which prevents page to work normally
The error:
Uncaught SyntaxError: Unexpected end of JSON input
at JSON.parse (<anonymous>)
at chanspec.js:25
The problem:
JavaScript:
if(based_modelid == "RT-AC87U"){
ch80m = JSON.parse(''); #<---- here should be JSON.parse('{}')
wl1.channel_80m.push("0");
for(i=0;i<ch80m.length;i++){
wl1.channel_80m.push(ch80m[i] + "/80");
ch40m = JSON.parse(''); #<---- here should be JSON.parse('{}')
wl1.channel_40m.push("0");
for(i=0;i<ch40m.length;i++){
wl1.channel_40m.push(wlextchannel_fourty(ch40m[i]));
please fix. Thank you in advance
What browser is that with? Have you tried any troubleshooting? What steps, if any?
Does clearing the cache work? Rebooting the computer, router, or both?
The error:
The problem:
JavaScript:
It must be something with your browser? Mine works as it should, no errors in display.
First browser was chrome latest
Tried to clear cache, tried with dev tools 'Disable cache'
Than I tried to change browser to fresh installed Firefox latest - the same.
Than I debugged the source code
As I've mentioned earlier the problem is in JS file. JSON.parse('') is a bug because json can't be empty. it must consists at least with '{}'
