Asus AIMesh - how to 'push' network changes to nodes
charsiufan
I recently set up an Aimesh - main router is a 4G-AC68U, the 3 nodes are RT-AC68U's - all connected by ethernet cable.
The mesh appears to be working for the most part. All boxes are visible from the main router and the app.
However, I set up a 'Guest Wifi' on the main box but its not showing in areas of the house that are out of range of the main router.
Also, if I change the password on the main router - it doesn't change on the nodes - as I can't use the new password in areas of the house where the main router has no signal.
thanks
