Asus CT8 LED lights and Connectivity
mikenott
Realise this is an AX forum, but can't see anywhere else to ask about my CT8 so hope you will indulge me as the two routers are very similar.
I have two new CT8 routers which have updated firmware and connected to a Virgin Hub 3.0 set to modem-only mode. I have followed all the set up instructions several times with factory resets etc. etc. The problem is that my (only) LED light on the router/node do not go to bright white after set up is complete but to a light blue which, according to the manual/internet, means they are "ready for set up". During the set up process the LED does flash on as bright white for a second but it then goes out. As I say, I have rebooted/reset/updated several times and both are at factory default settings except for changing the wireless channel SSID and password. . The system SEEMS to be OK - the pictograph showing connections shows solid green lines between router and AI Mesh node and signal strength seems good when measured by a wireless speed app although I do notice a slow speed initially (30-40Mb/s) when I move to a different room/node - which subsequently recovers to what I would expect (circa 200Mb/s).
1. Has anybody else had this lights issue?
2. Is the slow initial speed typical?
3. Any tips on how to overcome them?
Any info/thoughts gratefully received :):rolleyes::)
Michael
