Asus GT-AX11000 5Ghz-2 160Mhz not working
ZerOneX
Hi guys, my first post here after 3 months with my AX11000 trying everything i could.....
Will give all the context i can:
- I am from Canada
- The firmware is the 3.0.0.4.388_23285-g5068da5
- I have a desktop with a wi-fi 6E card
- I am connecting only it on my 5Ghz-2
- The 5Ghz-2 is using wif ax mode only, Channel bandwidth 160Mhz and control channel 104
No matter what I do, when i connect to it, my desktop shows me RZ608 Wi-Fi 6E 80MHz 1201/1201 (Mbps) as link speed.
Would anyone could give me any advice?
As far as I can tell i tried everything i could.
If anyone needs any extra info, it will be a pleasure to share.
Thank you in advance.
Best regards,
ZerO.
- I am from Canada
Best regards,
ZerO.
I'm not familiar with channel allocation in your region...
What does the Wireless Log report regarding DFS detection/status?
OE
Thank you very much for replying.
This is what i have on my log and i think i got why.
As i am using channel 104 and as I have RADAR sentive on my log, I should use one of the following channels
Channel 149 A Band
Channel 153 A Band
Channel 157 A Band
Channel 161 A Band
Channel 165 A Band
Am I right?
Thank you for replying, this is what I have on my log:
SSID: "2.4Ghz"
noise: -92 dBm Channel: 6
BSSID: XX:XX:XX:XX:XX:XX Capability: ESS RRM
Supported Rates: [ 1(b) 2(b) 5.5(b) 6 9 11(b) 12 18 24 36 48 54 ]
VHT Capable:
Chanspec: 2.4GHz channel 6 20MHz (0x1006)
Primary channel: 6
HT Capabilities: 40Mhz SGI20 SGI40
Supported HT MCS : 0-31
Supported VHT MCS:
NSS1 Tx: 0-11 Rx: 0-11
NSS2 Tx: 0-11 Rx: 0-11
NSS3 Tx: 0-11 Rx: 0-11
NSS4 Tx: 0-11 Rx: 0-11
Interference Level: Acceptable
Mode : AP Only
Stations List
idx MAC Associated Authorized RSSI PHY PSM SGI STBC MUBF NSS BW Tx rate Rx rate Connect Time
XX:XX:XX:XX:XX:XX Yes Yes -71dBm n No Yes Yes No 1 20M 28.9M 5.5M 00:04:13
XX:XX:XX:XX:XX:XX Yes Yes -54dBm n Yes Yes Yes No 1 20M 65M 6M 00:04:28
XX:XX:XX:XX:XX:XX Yes Yes -57dBm n Yes Yes Yes No 1 20M 72.2M 6M 00:04:43
XX:XX:XX:XX:XX:XX Yes Yes -61dBm n Yes Yes No No 2 20M 6.5M 11M 00:04:45
XX:XX:XX:XX:XX:XX Yes Yes -52dBm n Yes Yes Yes No 1 20M 72.2M 11M 00:04:47
XX:XX:XX:XX:XX:XX Yes Yes -51dBm n No Yes No No 1 20M 72.2M 72.2M 00:04:48
XX:XX:XX:XX:XX:XX Yes Yes -44dBm n No Yes Yes No 1 20M 72.2M 6M 00:04:49
XX:XX:XX:XX:XX:XX Yes Yes -62dBm n No Yes Yes No 1 20M 6.5M 6M 00:04:49
XX:XX:XX:XX:XX:XX Yes Yes -50dBm n No Yes Yes No 1 20M 65M 6M 00:04:49
XX:XX:XX:XX:XX:XX Yes Yes -37dBm n Yes Yes No No 1 20M 72.2M 6M 00:04:50
XX:XX:XX:XX:XX:XX Yes Yes -44dBm n Yes Yes No No 2 20M 130M 11M 00:04:50
SSID: "5Ghz-1"
noise: -90 dBm Channel: 48/80
Supported Rates: [ 6(b) 9 12(b) 18 24(b) 36 48 54 ]
HE Capable:
Chanspec: 5GHz channel 42 80MHz (0xe32a)
Primary channel: 48
Supported VHT MCS:
Supported HE MCS:
80 Mhz:
160 Mhz:
Mode : AP Only
DFS status: state IDLE time elapsed 0ms radar channel cleared by DFS none
Channel Information
Channel 36 A Band
Channel 40 A Band
Channel 44 A Band
Channel 48 A Band
Channel 52 A Band, RADAR Sensitive, Passive
Channel 56 A Band, RADAR Sensitive, Passive
Channel 60 A Band, RADAR Sensitive, Passive
Channel 64 A Band, RADAR Sensitive, Passive
Stations List
XX:XX:XX:XX:XX:XX Yes Yes -70dBm ax Yes Yes No No 2 80M 907.4M 24M 00:04:47
XX:XX:XX:XX:XX:XX Yes Yes -64dBm ax Yes Yes No No 2 80M 907.4M 6M 00:04:48
XX:XX:XX:XX:XX:XX Yes Yes -65dBm ac Yes Yes No No 2 80M 585M 526.5M 00:04:52
XX:XX:XX:XX:XX:XX Yes Yes -62dBm ax No Yes Yes Yes 2 80M 960.7M 680.5M 00:04:54
XX:XX:XX:XX:XX:XX Yes Yes -39dBm ax No Yes Yes Yes 2 80M 1201.0M 1134.2M 00:04:55
SSID: "5Ghz-2"
noise: -88 dBm Channel: 104/160
HE Capable:
Chanspec: 5GHz channel 114 160MHz (0xe972)
Primary channel: 104
Supported VHT MCS:
Supported HE MCS:
80 Mhz:
160 Mhz:
Mode : AP Only
DFS status: state In-Service Monitoring(ISM) time elapsed 235650ms radar channel cleared by DFS channel 104/160 (0xE972)
Channel Information
Channel 100 A Band, RADAR Sensitive
Channel 104 A Band, RADAR Sensitive
Channel 108 A Band, RADAR Sensitive
Channel 112 A Band, RADAR Sensitive
Channel 116 A Band, RADAR Sensitive
Channel 120 A Band, RADAR Sensitive
Channel 124 A Band, RADAR Sensitive
Channel 128 A Band, RADAR Sensitive
Channel 132 A Band, RADAR Sensitive, Passive
Channel 136 A Band, RADAR Sensitive, Passive
Channel 140 A Band, RADAR Sensitive, Passive
Channel 144 A Band, RADAR Sensitive, Passive
Channel 149 A Band
Channel 153 A Band
Channel 157 A Band
Channel 161 A Band
Channel 165 A Band
Stations List
Channel 149 A Band
Channel 153 A Band
Channel 157 A Band
Channel 161 A Band
Channel 165 A Band
Am I right?
If RADAR/DFS is active, then avoid using those channels... use a non-DFS control channel and likely 80MHz max bandwidth.
OE
yeap, i live near by an airport!
so, no scenario at all where i could use 160mhz?
even buying a new router?
i do a lot of fiel transfer using my wireless network and unfortunately, a wired network is not an option.
thank you OE.
thank you OE.
If the Log doesn't show a steady (ch#/160), then DFS is affecting wireless connections/clients... I would not use that with any router.
OE
- I am from Canada
Best regards,
ZerO.
Hello, I have the Asus AX11000 in the US but I can never get 160Mhz working on 5Ghz-2? I have changed the settings between 5Ghz-1 and 5Ghz-2 and it works on 1 but not 2? Even when I choose 160 it sets to 80. I've tried hard resets, Merlin firmware, what is going on? TY in advance.
You have 3x 160MHz wide channels only on 5GHz band - Ch.50 in lower 5GHz band, Ch.114 in the middle and Ch.163 in upper range. Your 5GHz-1 radio is perhaps okay with clear DFS, but your 5GHz-2 radio may not allow weather radar DFS and it perhaps doesn't support U-NII-4 on your router. There is no client device with U-NII-4 support as far as I know, only useful for wireless backhaul to another router, when supported. So your 5GHz-2 radio is perhaps limited up to 80MHz wide channel only.
I just hard reset and it still only does 160 Mhz on 5ghz 1. Even if I set 5ghz 1 to 80Mhz it still won't let me choose 160Mhz o 5ghz 2? What is going on? Any help would be appreciated.
Try 5GHz-1 36/160 and 5GHz-2 100/160 and see what happens.
For better Wi-Fi stability I would recommend 5GHz-1 36/80 and 5GHz-2 149/80. The use of DFS channels is not guaranteed.
Thank you so much brother! It worked! I don't understand why auto channel on the 5Ghz-2 was causing me to be stuck at 80? But looking now I can pick from channels 100, 104, 108, 112, 116, 120, 124, 128 yet when I select 120, 124 or 128 (I'm in the US and shouldn't be seeing these, right?) it doesn't actually go to those channels even though it says it but in the wifi channel logo green icon at the top of the gui it shows channel 104 but then I'm limited to 80. I just tried changing the control channel to 104 and it says I'm on channel 161/80 even though 160 is still selected? Edit 2: I set the control channel to 100 again like before and now it says I'm on channel 149/80, so I can't get back my 160 now, lol. But oddly on my 5ghz -1 on channel 36 I just lost 160 and its now 80? Why is this happening? Asus GT-AX11000 running Merlin 3004.388.6_0_rog. My connection speed over wifi 160 is 1.2Gbps download and 42Mbps upload. I'm using Xfinity SB8200 with WAN link aggregation on my Asus GT-AX11000.
EDIT: A long time ago I tried changing my device location to a country used in a thread: https://gist.github.com/francoism90/3dede7973354d067c41bff5e54203fe9#file-readme-md
But nothing happened, I never created the JFSS file and I thought everything reset up reboot? Since then I've hard reset both with the reset button and GUI method. Is this causing this? Can anyone help me check and reset everything back if that is the issue? Thank you in advance.
SSID: "XXXXXXXXXX"
noise: -86 dBm    Channel: 3l
BSSID: D4:5D:64:EC:90:90    Capability: ESS ShortSlot RRM
HT Capable:
    Chanspec: 2.4GHz channel 5 40MHz (0x1805)
    Primary channel: 3
Mode    : AP Only
SSID: "XXXXXXXXXX"
noise: -91 dBm    Channel: 36/80
BSSID: D4:5D:64:EC:90:94    Capability: ESS RRM
HE Capable:
    Chanspec: 5GHz channel 42 80MHz (0xe02a)
    Primary channel: 36
    Supported VHT MCS:
    Supported HE MCS:
        80 Mhz:
        160 Mhz:
Mode    : AP Only
DFS status: state IDLE time elapsed 0ms radar channel cleared by DFS channel 36/160 (0xE832)
Channel Information
Channel 36    A Band
Channel 40    A Band
Channel 44    A Band
Channel 48    A Band
SSID: "XXXXXXXXXX"
noise: -90 dBm    Channel: 161/80
BSSID: D4:5D:64:EC:90:98    Capability: ESS RRM
Supported Rates: [ 6(b) 9 12 18 24(b) 36 48 54 ]
HE Capable:
    Chanspec: 5GHz channel 155 80MHz (0xe39b)
    Primary channel: 161
    Supported VHT MCS:
    Supported HE MCS:
        80 Mhz:
        160 Mhz:
Mode    : AP Only
DFS status: state IDLE time elapsed 0ms radar channel cleared by DFS channel 100/160 (0xE872)
Channel Information
Channel 100    A Band, RADAR Sensitive, Passive
Channel 104    A Band, RADAR Sensitive, Passive
Channel 108    A Band, RADAR Sensitive, Passive
Channel 112    A Band, RADAR Sensitive, Passive
Channel 116    A Band, RADAR Sensitive, Passive
Channel 120    A Band, RADAR Sensitive, Passive
Channel 124    A Band, RADAR Sensitive, Passive
Channel 128    A Band, RADAR Sensitive, Passive
Channel 149    A Band
Channel 153    A Band
Channel 157    A Band
Channel 161    A Band
Channel 165    A Band
You cannot get 5GHz 160MHz channel width without using DFS except the single case of including UNII-4, and as has been noted, no clients yet have those extra channels at the top of the 5-GHz band. And most routers don't either. So even if you're using the equipment somewhere 160MHz is /available/ there are no guarantees it will always, if ever, be usable. The most you can (legally) do is select the configuration and hope for the best.
I very highly doubt one can successfully alter their equipment location settings, even temporarily, on anything made the last few years. Like it or not, your government is, if not smarter, at least more powerful than you, and such settings have lately been "burned into" the equipment at a level deeper than is accessible without special equipment and knowledge.
